AE85 To KE70 Front Rotors...
Postby pervert » Thu Sep 22, 2005 11:21 am
Firstly, are AE85 front brakes much bigger than KE70 ones?
Secondly, is it a bolt on swap, or do you need more than just the discs/calipers...???
8)
pervert
Postby Jebus » Thu Sep 22, 2005 11:33 am
Theyre both around 9" solid, not worth doing
Jebus
Postby pervert » Thu Sep 22, 2005 11:43 am
Thanks... 8)
pervert
Postby MetalupYoAss » Thu Sep 22, 2005 11:29 pm
yeah ae85 and ke70 front brakes and suspension are the same
MetalupYoAss
Postby CozmoNz » Thu Sep 22, 2005 11:43 pm
have a look @ the coronas brakes pervert....
Rayne For President!
CozmoNz
Postby Jebus » Thu Sep 22, 2005 11:55 pm
If you want to do an upgrade, probaly not necessary tho? Use celica struts and brakes, of the R/TA63 variety, skip cressida and corona etc or youll be likely to run into the issues ive had :(
Jebus
Postby pervert » Fri Sep 23, 2005 12:07 am
I'm not doing shit that isn't direct bolt in right now... :lol: :lol: :lol: :lol: :lol:
Thanks anyway.
pervert
Postby Jebus » Fri Sep 23, 2005 12:11 am
I no longer trust the words 'Direct bolt in' or 'Drops straight in' Nothing $&#$% is. If it goes i wouldnt bother touching it :lol:
Jebus
Postby fangsport » Fri Sep 23, 2005 8:10 am
just bang some good pads in the standard brakes.............direct drop in :wink:
fangsport
Postby pervert » Fri Sep 23, 2005 9:42 am
fangsport wrote:just bang some good pads in the standard brakes.............direct drop in :wink:
Yup, that's the plan, faaaar easier... :lol:
Any good brands to try and get a hold of...
Jebus> I know what you mean! I changed my black plastic door handles to chrome ones last night, and even something that basic wasn't just a straight swap!!! All the clips and shit were different!!! :roll:
pervert
Postby AE85coupe » Fri Sep 23, 2005 11:56 am
AE85 brakes are bigger than ke70 sedan brakes, but the same size as TE71 and KE70 wagon brakes
celica TA61/TA63 struts with 10 inch vented discs is a straight swap
as long as you use the steering arms off the celica, and use your original top hat and springs
its really piss easy
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby wde_bdy » Sat Sep 24, 2005 10:15 am
Get some Mintex pads from 0800 Brakes, around $200 ish.
http://www.racebrakes.co.nz/
Callum
wde_bdy
Postby pervert » Sat Sep 24, 2005 11:03 am
purple_beasty wrote:Get some Mintex pads from 0800 Brakes, around $200 ish.
Callum
Thanks, I take it for $200 these things are going to stop me in a $&#$% hurry (even with the standard discs/calipers), and not fade overly easy???
I have quite a problem with bad fade... :lol:
pervert
Postby wde_bdy » Sat Sep 24, 2005 11:40 am
Dunno, will tell you when my car is going lol
I bought a set for my 18R-GE KE70 ute, but haven't got it up to cert status yet. A friend used them with standard discs on a 4AGE 20V powered KP Starlet, has been around Pukekohe a few times with no problems. If you still have problems with fade after fitting them look at ducting your brakes.
Callum
wde_bdy
Postby Ke70 » Sat Sep 24, 2005 10:33 pm
AE85coupe wrote:AE85 brakes are bigger than ke70 sedan brakes, but the same size as TE71 and KE70 wagon brakes
Hi, I have some MX73 Cressida( same 10inch vented disks are they not?) front struts that i am wanting to put into my ke70.Are you saying all i will need to do is find some TA61/TA63 Carina/Celica steering arms and my original springs and top hats?
Ke70
Postby AE85coupe » Sun Sep 25, 2005 12:03 pm
umm just use the MX73 steering arms
an yeah it should work (can't gurantee as i don't know if MX73 struts are exactly like TA63 etc.)
Details of car here
AE85coupe
Postby Jebus » Sun Sep 25, 2005 7:35 pm
No that wont work, celica steering arms give positive camber, then youll need camber plates, then youll need coil overs. Its not as easy a swap as it seems
Jebus
Postby fangsport » Mon Sep 26, 2005 5:38 pm
Callum
good pads, but a bit extreme for a standard-ish road car.
can't remember what flavour i fitted (Bendix metal king???), but they were $60 for the fronts. pulls the car up good, don't seem to fade and work good (ish!) when cold. done three seasons of club champs plus 3 full days of rallying and still going strong.
fangsport
Postby wde_bdy » Mon Sep 26, 2005 6:14 pm
Running the 1155 compound mintex pads for my KE70 ute, its an endurance racing type pad so should suit a bit of towing and the heavy 18RG sitting up front. Remember Pervert is running some large wheels, make a hug difference to braking with all the extra weight on the outer circumference. Probably why he is having such a fading problem.
Callum
wde_bdy
