Secondly, is it a bolt on swap, or do you need more than just the discs/calipers...???
fangsport wrote:just bang some good pads in the standard brakes.............direct drop in
purple_beasty wrote:Get some Mintex pads from 0800 Brakes, around $200 ish.
http://www.racebrakes.co.nz/
Callum
AE85coupe wrote:AE85 brakes are bigger than ke70 sedan brakes, but the same size as TE71 and KE70 wagon brakes
celica TA61/TA63 struts with 10 inch vented discs is a straight swap
as long as you use the steering arms off the celica, and use your original top hat and springs
its really piss easy
Callum
