hi all,
could someone tell me if this is suitable for my mr2 3sgte ?
as i put some in and then i turned it on and 5 mins later it started to blow white smoke out.
thank you
Mmm, Boost wrote:Its definately not suitable, I think the factory recommendation is a 10w40. 15w50 if its higher k's. 25w50 is suitable for dirty old bogan V8's with massive ring clearances
LEV_101 wrote:Mmm, Boost wrote:Its definately not suitable, I think the factory recommendation is a 10w40. 15w50 if its higher k's. 25w50 is suitable for dirty old bogan V8's with massive ring clearances
its only done 80000. will there be any problems ?
