best tool/way to machine out internal gate?
Postby escortman » Tue Nov 04, 2008 6:38 am
ok so im getting real bad boost creep as the port is tiny on my td05 20g
what have u guys done to enlarge them ?
cheers[/quote]
4x4 toyota blizzard offroader
escortman
Postby evil_si » Tue Nov 04, 2008 7:40 am
ive bored a few out, milling is the best way to do it,
can die grind them with a carbide burr but it takes forever
have recently also setup an external wastegate on the actual turbine housing, machined in just below the exhaust inlet and set it up there, works really well
this is a similar pic i found on mmc to what ive just done on an evo
evil_si
Postby d1 mule » Tue Nov 04, 2008 7:42 am
i dont no if you can get them for a td05 flange but this could be an idea??
http://www.drivenperformance.co.nz/scri ... roduct=564
d1 mule
Postby escortman » Tue Nov 04, 2008 7:54 pm
evil_si wrote:ive bored a few out, milling is the best way to do it,
yeh im thinking myt see if mates mill is up and running
yeh i looked into that but would be a bit to tight
escortman
Postby escortman » Tue Nov 04, 2008 7:55 pm
d1 mule wrote:i dont no if you can get them for a td05 flange but this could be an idea??
yeh prblem with them if i could find a td05 1 would be the turbo my be to low
escortman
Postby escortman » Tue Nov 04, 2008 8:05 pm
meh his millers been shifted and got no power now, so hes just going to weld my external into the manifold
cheers for the input guys
escortman
Postby deaf_rattle » Tue Nov 04, 2008 8:05 pm
[/img]
oooh, so you can do that? thats what we are thinking about doin with the 7m and gt3582R
