ok so im getting real bad boost creep as the port is tiny on my td05 20g
what have u guys done to enlarge them ?
cheers[/quote]
evil_si wrote:ive bored a few out, milling is the best way to do it,
can die grind them with a carbide burr but it takes forever
have recently also setup an external wastegate on the actual turbine housing, machined in just below the exhaust inlet and set it up there, works really well
this is a similar pic i found on mmc to what ive just done on an evo
d1 mule wrote:i dont no if you can get them for a td05 flange but this could be an idea??
http://www.drivenperformance.co.nz/scri ... roduct=564
[/img]
