Adamal wrote:Its possible that the clutch is buggered. I had a mate with an AW with a GZE which had that problem.
mr30%jr wrote:i dont think its a ignition issue. otherwise the car would have trouble running as a total
it will limp, and not recognise the throttle is wide if this not turning on the s/c and not providing spark or fuel at the correct RPM
i would be very suspect of the dizzy pick up and map.
