4agze missing
Postby Adamal » Tue Nov 25, 2008 11:12 pm
Its possible that the clutch is buggered. I had a mate with an AW with a GZE which had that problem.
Postby beeker » Wed Nov 26, 2008 6:07 am
Adamal wrote:Its possible that the clutch is buggered. I had a mate with an AW with a GZE which had that problem.
How do i test ?
Is there a process, other than driving it ?
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby rollaholic » Fri Nov 28, 2008 9:02 am
mr30%jr wrote:i dont think its a ignition issue. otherwise the car would have trouble running as a total
it will limp, and not recognise the throttle is wide if this not turning on the s/c and not providing spark or fuel at the correct RPM
i would be very suspect of the dizzy pick up and map.
its perfectly possible to have intermittent ignition faults, or faults that only show under certain conditions
Postby jondee86 » Sun Nov 30, 2008 12:02 am
Keep driving it !!! It's getting better all the time. By the time you
put another 100 km on it, should be sweet as :)
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby beeker » Sun Nov 30, 2008 9:05 pm
Update:
I noticed when the boost came on, it only boosted to 5psi, so i rechecked the IC plumping. err, yes, a "quick" check was obviously performed, there was a major clamp loose and thus boost leak. Fixed that, and its back to ~10psi (12psi pulley fitted).
However, the S/C is still intermittent.
Had the S/C relay checked by a professional last week, and was ok on the bench. However, i'm told that doesnt mean allot.
Will probably drop off the car at to a auto sparky next week and just isolate if its electrical or mechanical, and go from there.
Perhaps a pemanent ON for the S/C ? during testing?
06 RS4 Avant
beeker
Postby beeker » Tue Dec 16, 2008 7:21 pm
Solved.
It was the ECU. Inserted a loaner ECU, and problem goes away. When ever i insert my ECU, problem comes.
A BIG thanks to Rick for the loaner ECU!
Wanted: ECU for Map 4agze (AE101)
06 RS4 Avant
beeker
