intercooler too big?
Postby Logan » Fri Aug 27, 2004 11:26 am
because the charger is still using crank power to turn it, which in turn is not being fed back into the motor and been vented, hence wasted power...
SR Sold. Onto Other Things
Logan
Postby Bazda » Fri Aug 27, 2004 12:00 pm
just leave the TB where it is, and get a nice size cooler like a Vr4 cooler and i bet u will hardly notice the acceleration when u let go of the throttle.
guy who lives near me done it to his car with standard boost and it still retained the standard boost when he put a spec front mount on, large surface area but a thin cooler with only using 2" pipes to plumb it.
Postby wanado13's » Wed Sep 01, 2004 11:52 am
thanks for all the help the idea of moving the throttle body will be the go but will moving it to after the supercharger mean that my supercharger is constantly spinning or something?
wanado13's
Postby gdsup » Wed Sep 01, 2004 5:43 pm
your s/c clutch is ecu controlled, from memory it something like 5~7 inchs of vacum, it will switch on, and after you back off it delays the disengagment of the clutch a futher 5 seconds, the reason behind this is not to over use and wear the s/c clutch every time you change gear etc etc
gdsup
Postby 4AGTE » Fri Sep 03, 2004 8:50 am
Well i don’t know what every one is talking about as i have a massive intercooler and heaps of piping for the front mount. Please see picture beside this and the intercooler goes to the top of the bumper.
I have an aftermarket pulley (Home made for extra boost and bigger than any aftermarket one you can buy) and have had no problems with coming on boost but i have a delay when coming off the throttle of about 1 second.
Whether or not the pulley has something to do with this i do not know but you can’t buy a much bigger intercooler than what i have.
So i can’t really see the point of changing the set up to the degree that has been said here. It may work but you might as well turbo as it will be easier and only cost a little more to do.
For the original guy wants to know where are you from? You might be able to come see mine or i can e-mail pictures to you.
4AGTE
Postby 4AGTE » Fri Sep 03, 2004 8:51 am
oh yeah and i have riped the pressure release valve completly off.
4AGTE
Postby EVLGTZ » Fri Sep 03, 2004 8:53 am
4AGTE wrote: but i have a delay when coming off the throttle of about 1 second.
Umm thats what this post is all about mate :lol:
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby vvega » Fri Sep 03, 2004 10:39 pm
when your point to point racing 1 second is a bloddy long time
personally i think moving the t/b would be a exerlent idea :D
v
vvega
Postby 4AGTE » Sat Sep 04, 2004 7:23 am
comming OFF the throtle. Who cares about that its on that you dont want lag and that is only at low rev's. 5000rpm and above no problems.
Was bad and took corolla for skid last night.
4AGTE
Postby wanado13's » Sun Sep 05, 2004 4:58 pm
4agte you got a pm
wanado13's
Postby the fallen303 » Sun Sep 05, 2004 5:13 pm
what is the throttle responce like on a stock setup map gze? does it still have the lag after throttle off? is it really as bad as you guys are talking about? what about changing the top mount air to air, to a water to air i/c? would this be better than running the factory air to air?
true house of JZ
Stay true to the origin
the fallen303
Postby Monsterbishi » Sun Sep 05, 2004 7:26 pm
the fallen303 wrote:what is the throttle responce like on a stock setup map gze? does it still have the lag after throttle off? is it really as bad as you guys are talking about? what about changing the top mount air to air, to a water to air i/c? would this be better than running the factory air to air?
It really is as bad as we say, and the only way to stop it is to move the TB, and then run a nice big BOV to evacuate the excess air that is between the TB and the SC when the throttle closes.
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby the fallen303 » Sun Sep 05, 2004 7:37 pm
would an hks ssbov do alright in venting the amount of boost?
true house of JZ
the fallen303
Postby Logan » Sun Sep 05, 2004 9:36 pm
so are you guys saying tb at the plenum or b4 supercharger? \from an autospeed artcile \9or was it an old zoom mag?? Anyhows bosch plastic BOV's flow really well, couple of them would do the trick,,,,
Logan
Postby mike simmonds » Mon Sep 06, 2004 1:33 pm
im sure any bov will do, there is no need for a big bov! the more air that goes out the bov the more u will have to build up in all the piping and intercooler, if u have a big cooler it will take a while to build pressure up again. all u need to do is vent the pressure the sc builds up wen it is spinning after the tb is closed.
mike simmonds
Postby mike simmonds » Mon Sep 06, 2004 1:37 pm
throttle response is GOOD wen it is stock! only wen u put piping to a big cooler does throttle response become bad!
mike simmonds
Postby the fallen303 » Mon Sep 06, 2004 2:33 pm
would changing the top mount air to air i/c to a water to air and leave it top mount help at all? say a legacy rs unit? that way the air will be getting colled better than the current top mount setup, and the piping will be still the same length so the throttle responce will still be alright.
any thoughts?
true house of JZ
the fallen303
Postby FLAWLES » Mon Sep 06, 2004 6:46 pm
or you can buy " if you still can " a top mount hks intercooler thats bigger dont no if it would be any diff tho
with the water to air i/c u still would be getting heat soak wouldnt u?
FLAWLES
Postby the fallen303 » Tue Sep 07, 2004 12:22 am
you would, but the heat soak would be heating the water, which is getting circulated away to the front mounted radiator for the setup, so gets cooled down anyway.
true house of JZ
the fallen303
Postby 4AGTE » Tue Sep 07, 2004 8:50 am
Fallen you will have to come drive my corolla since you are in hamilton and make up your mind of how mine proforms.
I dont think it is as bad as every one believe's.
4AGTE
Users browsing this forum: Google [Bot] and 17 guests
