The theory of boost?
Postby GorGasm » Mon Jan 23, 2006 8:36 pm
The subbie sequential is a sack of shit. 4 psi at 4krpm and 13 psi at 7, coupled with a 8.5 CR and you get a pig.
GorGasm
Postby Si » Mon Jan 23, 2006 8:44 pm
difference in the systems is AFAIK is the subbie uses two different sized turbos (vf8 and vf10?)
vs the supra and rx7 using same sized turbos but set up sequentialy......
Current: , '96 SubaruImpreza
Si
Postby SUBARUCONVERT » Mon Jan 23, 2006 9:00 pm
The subaru uses a same sizied turbo setup, abilt with a silghtly differnt A/R on the exhuast housing. The older ones arnt that quick, but the GTB versions are. the power isnt smooth but i think people are strechin the story with no power from 4-5K and only 4psi boost. everyone i have driven the VOD lasts about 500 rpm. they make max torque at 5k so that really doesnt sound rite. They pull well all the way to 7.5 or 8k depending on model unlike some other TT's (cough VR-4)
SUBARUCONVERT
Postby CozmoNz » Mon Jan 23, 2006 9:02 pm
Quite interesting when you see the setup without the engine in there :D, very cool..
wastegate.. no wastegate... what the hell!
Rayne For President!
CozmoNz
Postby Dell'Orto » Mon Jan 23, 2006 9:44 pm
SUBARUCONVERT wrote:. the power isnt smooth but i think people are strechin the story with no power from 4-5K and only 4psi boost. everyone i have driven the VOD lasts about 500 rpm.
Nup, the one I drove (I'd just put a boost gauge into) dropped right back to 1-2psi at 4k, then jumped back up to 7 at 5...completely stock standard car though, with a decent intake and exhaust it might be better.
Postby SUBARUCONVERT » Mon Jan 23, 2006 11:17 pm
sounds like theres somthing wrong with it, the boost shouldnt drop any lower than 5 psi during VOD, and once the second turbo is spooled boost should reach 10 psi or more regaurdless of model
SUBARUCONVERT
Postby neon_spork » Mon Jan 23, 2006 11:56 pm
Time for an engineer to shed some light on the fluids side of things...
The mass flow rate will be the same at any point. kg/second
You are talking about volume flow rate (cfm) or in proper units, m^3/second. and Pressures (bar or psi) or in SI units kPa.
If you treat air as an idea gas (which should be pretty accurate) then the relationship is Pv = RT
P = pressure in kPa,
v = specific volume (Volume/Mass)
R = Gass constant for air
T = temperature in Kelvin
Volume flow rate is equal to the area x velocity (m^2 x m/s = m^3/s) Area of the inlet and velocity of the air can be measured.
Mass flow rate is equal to the volume flow rate x density (m^3/s x kg/m^3 = kg/s)
Inlet temperature can be measured, pressue at this point is known to be 1atmosphere or 101.3 kPa and from these density can be calculated or taken from a table.
specific volume = 1 over mass flow rate x volume flow rate (s/kg * m^3/s = m^3/kg)
So if you know ur volume flow rate and you mass flow rate at a point you can get the specifi volume (v). Then using the Idea gas equation you can find the pressure.
Pressure = R.T/v
R(gas constant) for air is 0.286 kJ/kg.K
T(temp in K) = deg C + 273
Hope that helps
neon_spork
Postby Stealer Of Souls » Tue Jan 24, 2006 8:07 am
neon_spork wrote:Time for an engineer to shed some light on the fluids side of things...
Pressure = R.T/v
Hope that helps
What happened to the n (number of mols) in the gas equation?
Anyways. Too much math. More general please.
I am an engineer. Just not a fluids person. It's all getting so technical.
fivebob wrote:No, it's not a linear relationship. Theorectically New Flow Rate = Old Flow Rate x the square root of (New Pressure divided by Old Pressure), but that may not be what happens in real life as the infernal combustion engine is a bit more complicated than the usual "pressure vs flow" model.
Okay cool. But my general thinking is correct. Complex physics aside. With roughly twice the flow (2x160CFM), I would end up with around about twice the pressure (2BAR absolute). Give or take a number of factors.
Pv=nrT
assuming v, r, and T are constant (of course they wouldn't be... but for arguments sake).
P doubles, n doubles.
yeah?
'86 AE85.5 Levin
Stealer Of Souls
Postby Ako » Tue Jan 24, 2006 9:59 am
SUBARUCONVERT wrote:The subaru uses a same sizied turbo setup, abilt with a silghtly differnt A/R on the exhuast housing. The older ones arnt that quick, but the GTB versions are. the power isnt smooth but i think people are strechin the story with no power from 4-5K and only 4psi boost. everyone i have driven the VOD lasts about 500 rpm. they make max torque at 5k so that really doesnt sound rite. They pull well all the way to 7.5 or 8k depending on model unlike some other TT's (cough VR-4)
I love debunking this particular argument.
My TT VR4's all made power up to the 8200 limiter, with f-all of the boost a subby needed to make the same. The TT subbys have a reputation for being awesome at overtaking - the reason for that is the fact they suck at everything else, so the owners all push the one thing the cars good at :lol:
Simultaneous = win :D
Ako
Postby fivebob » Tue Jan 24, 2006 10:11 am
Stealer Of Souls wrote:
neon_spork wrote:If you treat air as an idea gas (which should be pretty accurate) then the relationship is Pv = RT
I think you will find that it's taken into account by using the specific volume which appears to be calculated as Volume/Mass, but I'm not an Engineer and the wording above is somewhat confusing to my poor wee uneducated mind :?
Pv=nrT
yeah?
No, from the equation I gave you need 4 times the flow for double the pressure, double pressure would only give 1.4 times the flow.
Postby CozmoNz » Tue Jan 24, 2006 2:06 pm
they have said it alot in this thread, its not pressure, its flow thats important...
what, 20psi on a ct9 is the same as 20psi on a ct20b? no.... excactly :P
CozmoNz
Postby Punter » Tue Jan 24, 2006 2:29 pm
CozmoNz wrote:they have said it alot in this thread, its not pressure, its flow thats important...
If you assume that the charge temp is the same, and its on the same motor with no other changes. Then yes thats exactally the same.
Although i'm sure in real life the exhaust housing on a ct9 would choke it up.
Punter
Postby Ako » Tue Jan 24, 2006 2:30 pm
Cozmo what are you on about?
Ako
Postby fivebob » Tue Jan 24, 2006 5:41 pm
No it's not. The CT-9 will have more restriction in the turbine so the flow will be less. How many times do I have to say it;
Boost pressure is caused by restriction in the system, flow makes the HP, not boost :roll:
If you knew that then why contradict yourself by saying they are the same. :?
Postby fivebob » Tue Jan 24, 2006 5:42 pm
Ako wrote:Cozmo what are you on about?
For once Cozmo is making sense and the rest of you are missing this momentous event :lol: :lol:
Postby Punter » Tue Jan 24, 2006 7:34 pm
Yea sorry that was badly worded , you now what i mean :lol:
Punter
Postby CozmoNz » Tue Jan 24, 2006 8:55 pm
quoted, notepadded, and saved, this is a rare event.
CozmoNz
Postby neon_spork » Wed Jan 25, 2006 10:41 am
Yeah your right, The equation P.V = n.Ru.T when V is volume and n is number of mols and Ru is the universal gas constant goes to P.v = R.T when you substitute specific volume v and the gas constant for a certain gas R.
neon_spork
Postby Stealer Of Souls » Wed Jan 25, 2006 11:34 am
neon_spork wrote:Yeah your right, The equation P.V = n.Ru.T when V is volume and n is number of mols and Ru is the universal gas constant goes to P.v = R.T when you substitute specific volume v and the gas constant for a certain gas R.
Are we okay to assume that V does not change in this instance?
'86 AE85.5 Levin
Stealer Of Souls
Postby SUBARUCONVERT » Wed Jan 25, 2006 6:47 pm
I guess its what u define as "power". My work mate that i car pool with has a 2.5 TT manual VR4 galant, it has a nice wide power band but to me dies above 5.5k, its not standard ethier.
SUBARUCONVERT
