SUBARUCONVERT wrote:. the power isnt smooth but i think people are strechin the story with no power from 4-5K and only 4psi boost. everyone i have driven the VOD lasts about 500 rpm.
neon_spork wrote:Time for an engineer to shed some light on the fluids side of things...
The mass flow rate will be the same at any point. kg/second
You are talking about volume flow rate (cfm) or in proper units, m^3/second. and Pressures (bar or psi) or in SI units kPa.
If you treat air as an idea gas (which should be pretty accurate) then the relationship is Pv = RT
P = pressure in kPa,
v = specific volume (Volume/Mass)
R = Gass constant for air
T = temperature in Kelvin
Volume flow rate is equal to the area x velocity (m^2 x m/s = m^3/s) Area of the inlet and velocity of the air can be measured.
Mass flow rate is equal to the volume flow rate x density (m^3/s x kg/m^3 = kg/s)
Inlet temperature can be measured, pressue at this point is known to be 1atmosphere or 101.3 kPa and from these density can be calculated or taken from a table.
specific volume = 1 over mass flow rate x volume flow rate (s/kg * m^3/s = m^3/kg)
So if you know ur volume flow rate and you mass flow rate at a point you can get the specifi volume (v). Then using the Idea gas equation you can find the pressure.
Pressure = R.T/v
R(gas constant) for air is 0.286 kJ/kg.K
T(temp in K) = deg C + 273
Hope that helps
fivebob wrote:No, it's not a linear relationship. Theorectically New Flow Rate = Old Flow Rate x the square root of (New Pressure divided by Old Pressure), but that may not be what happens in real life as the infernal combustion engine is a bit more complicated than the usual "pressure vs flow" model.
SUBARUCONVERT wrote:The subaru uses a same sizied turbo setup, abilt with a silghtly differnt A/R on the exhuast housing. The older ones arnt that quick, but the GTB versions are. the power isnt smooth but i think people are strechin the story with no power from 4-5K and only 4psi boost. everyone i have driven the VOD lasts about 500 rpm. they make max torque at 5k so that really doesnt sound rite. They pull well all the way to 7.5 or 8k depending on model unlike some other TT's (cough VR-4)
Stealer Of Souls wrote:neon_spork wrote:If you treat air as an idea gas (which should be pretty accurate) then the relationship is Pv = RT
What happened to the n (number of mols) in the gas equation?
Okay cool. But my general thinking is correct. Complex physics aside. With roughly twice the flow (2x160CFM), I would end up with around about twice the pressure (2BAR absolute). Give or take a number of factors.
Pv=nrT
assuming v, r, and T are constant (of course they wouldn't be... but for arguments sake).
P doubles, n doubles.
yeah?
Ako wrote:SUBARUCONVERT wrote:The subaru uses a same sizied turbo setup, abilt with a silghtly differnt A/R on the exhuast housing. The older ones arnt that quick, but the GTB versions are. the power isnt smooth but i think people are strechin the story with no power from 4-5K and only 4psi boost. everyone i have driven the VOD lasts about 500 rpm. they make max torque at 5k so that really doesnt sound rite. They pull well all the way to 7.5 or 8k depending on model unlike some other TT's (cough VR-4)
I love debunking this particular argument.
My TT VR4's all made power up to the 8200 limiter, with f-all of the boost a subby needed to make the same. The TT subbys have a reputation for being awesome at overtaking - the reason for that is the fact they suck at everything else, so the owners all push the one thing the cars good at![]()
Simultaneous = win
CozmoNz wrote:they have said it alot in this thread, its not pressure, its flow thats important...
what, 20psi on a ct9 is the same as 20psi on a ct20b? no.... excactly
Punter wrote:CozmoNz wrote:they have said it alot in this thread, its not pressure, its flow thats important...
If you assume that the charge temp is the same, and its on the same motor with no other changes. Then yes thats exactally the same.
Although i'm sure in real life the exhaust housing on a ct9 would choke it up.
fivebob wrote:Punter wrote:CozmoNz wrote:they have said it alot in this thread, its not pressure, its flow thats important...
No it's not. The CT-9 will have more restriction in the turbine so the flow will be less. How many times do I have to say it;
Boost pressure is caused by restriction in the system, flow makes the HP, not boostAlthough i'm sure in real life the exhaust housing on a ct9 would choke it up.
If you knew that then why contradict yourself by saying they are the same.
fivebob wrote:Ako wrote:Cozmo what are you on about?
For once Cozmo is making sense and the rest of you are missing this momentous event![]()
fivebob wrote:Stealer Of Souls wrote:neon_spork wrote:If you treat air as an idea gas (which should be pretty accurate) then the relationship is Pv = RT
I think you will find that it's taken into account by using the specific volume which appears to be calculated as Volume/Mass, but I'm not an Engineer and the wording above is somewhat confusing to my poor wee uneducated mind![]()
neon_spork wrote:Yeah your right, The equation P.V = n.Ru.T when V is volume and n is number of mols and Ru is the universal gas constant goes to P.v = R.T when you substitute specific volume v and the gas constant for a certain gas R.
Simultaneous = win
Users browsing this forum: Bing [Bot], Google [Bot] and 18 guests
