Best tyres for the job?
Postby flygt4 » Sat Jan 28, 2006 9:34 pm
i bought a set of 4 b4 xmas. 205/40/17 , retail price was $265 each 8O tho i dont know many people who pay retail for tyres anyway , i got mine a fair bit cheaper :D
the good stuff above all applies, great street tyre , sticky at low temps , great in the wet etc and awesome lateral grip thru corners.
i have twice heard of them being ripped to shreds and falling apart after 3 hard laps on a track so id say suitable for a street tyre only.
they lasted a 30minute hard drive through some twistys with no visible damage for me tho, so i wont complain :wink:
they also turn into very expensive smoke if one gets a little hasty
flygt4
Postby DB4G63 » Sat Jan 28, 2006 9:54 pm
Not inflate the F1s to over 30psi? I have 38psi in the rears and 34psi in the fronts Confused 205/40R17 front and 235/40R17 rear.
My tyre guy reckoned much more than that and your creating a concave surface, of which you are only rolling on the very middle of the tyre....so uneven tyre wear... or premature wear or somesuch.
:? hmm but i dont sell tyres, so its probibly just what he sez to ever customer....
I used to have some Hankook 195/55/15 and 38psi suited them just fine....
:roll:
"If I'm a child that means you're a pedophile, and I'll be damned if i'm going stand here and take this from a pervert."
Wheels: AE101 1993 GTZ Trueno (S/C)
DB4G63
Postby Al » Sat Jan 28, 2006 10:04 pm
Yeah I've had my F1's on for around 10,000km (since September) and they have worn so evenly it looks like they havent worn at all, with those pressures 8O
Al
Postby DB4G63 » Sat Jan 28, 2006 10:10 pm
Well that answers that! :D
DB4G63
Postby sergei » Sat Jan 28, 2006 10:52 pm
infact I think 30psi is a bit low for those tyres, I always get good kms out of them on 36-40psi...
Postby Quint » Sun Jan 29, 2006 11:00 am
Jeezh, that must make for a rough ride? i run 32 in the front 235/45 and 30 in the rear 255/40.
Quint
Postby Cyclone21 » Sun Jan 29, 2006 4:42 pm
I run these tyres on my car, they are excellent.
Cyclone21
Postby Si » Sun Jan 29, 2006 4:43 pm
quint, on my supra
(225/50r16, 245/50r16)
i have proxy T1R's on the front, and hankooks ho4ts on the rear,
fronts around 34-36 psi, rears 40ish in summer,
the toyos have very good grip in the wet, even more than the T1S's that i had on there before. just waiting to see what sort of KMS they will last for.
at this stage im thinking deff no more than 20,000kms.
im either going to 215/225 in 16 all round, or if my plans work 17" 215s,
i think 215s wont cut it for the rear end grip however,
Current: , '96 SubaruImpreza
Si
Postby tomo1985 » Mon Jan 30, 2006 10:15 am
Im running 40psi but they are 215/35/18 so you dont have much tire to play with.
tomo1985
Postby neo » Mon Jan 30, 2006 10:22 am
Leon wrote:They were the control tire for the Production Racing series last year, and the Evo's and WRX's were literally ripping the tire tread to bits in only a couple of races, so I can suggest that if you're doing hard track time, then you should avoid these tires. The same warning would apply for many soft road tires though :)
They tend to melt, even under the awesome pressure of a 20v at Taupo, I half used a brand new set at a toyspeed track day
neo
Postby Leon » Mon Jan 30, 2006 11:28 am
neo wrote:They tend to melt, even under the awesome pressure of a 20v at Taupo, I half used a brand new set at a toyspeed track day
Fudge ... ok, they're off my list then, as anything I own might have to put up with race track use. Wouldn't have thought they would die from the weight and power of an FXGT. I half killed a set of Yokohama commuter tires in no time flat myself on Manfeild, and it's very frustrating. Still, at least they only cost about $65 a corner ;)
Postby fivebob » Mon Jan 30, 2006 11:39 am
Probably too small a block size for track use, and they can't dissipate the heat quick enough. Might last longer if you shave them first (like you should with any new street tyre used on the track), but that cuts street mileage down drastically :cry:
Speaking of track tyres, what's the current selection of semi slicks like, do Yokohama still make the A032R?
Postby tomo1985 » Mon Jan 30, 2006 12:35 pm
Id be running atleast 32psi in them. Another good tire would have to be yokos A539.
tomo1985
Postby the fallen303 » Mon Jan 30, 2006 11:45 pm
dad has the F1's on the aristo, 265/18's all round, corners very nicely for an 1800kg car!! acceleration is also good, but being auto and traction control would help that a lot, lol. we had F1's on the back of the jza70 (225/50/16's) and i found that they did not grip as well in a straight line under heavy acceleration, but still cornered well (back wouldn't slide too badly). they do work very nicely on the front of the lucida van though :lol: keeps up with the supra and aristo through corners 8O
true house of JZ
Stay true to the origin
the fallen303
Postby Quint » Tue Jan 31, 2006 6:39 pm
Excuse the artist licence (couldn't find the damn sign.)
Quint
Postby 2LTR Rona » Tue Jan 31, 2006 7:10 pm
flygt4 wrote:i bought a set of 4 b4 xmas. 205/40/17 , retail price was $265 each 8O tho i dont know many people who pay retail for tyres anyway , i got mine a fair bit cheaper :D
snap, did exactly the same thing before xmas too, and couldnt agree more about the grip, well worth the money in my books 8)
2002 Altezza, 1974 KE25
2LTR Rona
