bluemaumau wrote:so how do you make the standard item bigger?
bluemaumau wrote:bluemaumau wrote:so how do you make the standard item bigger?
Mmm, Boost wrote:Now can anyone tell me the standard crank pulley size??
True-No-Turbo wrote:
Ive read on the aussie sites that they use an outer ring off a falcon crank pulley and press it onto the gze one to give larger diameter. Not certain what year falcon or exactly what the process is though. With the amount of mucking around your probley be better off saving the coin and buying a kit off Evil_Si, they are very well made and retain the factory Dampner. You get a new belt and small idler to suit - ready to boost!
evil_si wrote:Mmm, Boost wrote:Now can anyone tell me the standard crank pulley size??
standard is around the 155mm mark, they do vary from 153-156
Users browsing this forum: No registered users and 27 guests
