pulley kit
Postby bluemaumau » Sun Apr 09, 2006 11:09 pm
bluemaumau wrote:so how do you make the standard item bigger?
Postby Crucible » Mon Apr 10, 2006 2:17 pm
Ive read on the aussie sites that they use an outer ring off a falcon crank pulley and press it onto the gze one to give larger diameter. Not certain what year falcon or exactly what the process is though. With the amount of mucking around your probley be better off saving the coin and buying a kit off Evil_Si, they are very well made and retain the factory Dampner. You get a new belt and small idler to suit - ready to boost! :lol:
Crucible
Real Life Mechanic
Postby Dell'Orto » Sun May 07, 2006 11:08 pm
Now can anyone tell me the standard crank pulley size??
Postby bluemaumau » Sun May 07, 2006 11:12 pm
id tell you but i dont know if mines got a upgraded pulley or not, thats why i wanted to know!
*hooks up boost gauge 8) *
Postby evil_si » Mon May 08, 2006 7:14 pm
Mmm, Boost wrote:Now can anyone tell me the standard crank pulley size??
standard is around the 155mm mark, they do vary from 153-156
blitz 165mm
hks 170mm
cusco 173mm
esi's 175 - 185 mm :lol:
evil_si
Postby 2LTR Rona » Mon May 08, 2006 7:24 pm
yeah I have read that as well, can be found Here but in all honesty is far easier to just use the set up Evil_si makes, from those around here already running it, I have seen nothing but good feedback and should I go down that track with the KE25 then thats the way I'd go 8)
2002 Altezza, 1974 KE25
2LTR Rona
Postby beeker » Mon May 08, 2006 9:33 pm
I just had EvilSi fit a 12psi wheel on my targa 4agze ae86 car. I havnt really driven it since, but the product looked of good quality during the install. thumbs up.
Not sure how i'm gonna do timing though, as you have to cut that marker off during the install as the larger crank wheel would hit it.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby Dell'Orto » Mon May 08, 2006 10:30 pm
Thanks, just what I needed to hear ;)
