New engine should I be able to turn over by hand?
Postby Caveman » Mon Nov 27, 2006 10:00 pm
CAMB01 wrote:You shouldnt turn the crank without all the main caps torqued down.
if the crank is tight, start loosening the caps one by one till it turns.
Just what i was taught when i was working as a motor machinist for 3 years, and yes a rebuilt engine will be a little tight to begin with as the rings are scraping up and down the bores.
You do up the main caps 'tight' so everythings held in solid then as you torque them up give the crank a little give each way to make sure its still rotating :D I was taught this by my dad whos been a mechanic most of his life. We did it when replacing the bearings on my brothers 4agze.
I guess either way works. Could you explain why my method wouldnt work?
AW11 Track Toy
Formerly known as 1998
Caveman
Postby CAMB01 » Mon Nov 27, 2006 10:03 pm
what i thought you meant was just bolt one cap on then turn and then bolt another cap on.
If you turn the crank with no caps on, you will drag the bearing out of the groove, and will have to remove the crank to refit it.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Caveman » Mon Nov 27, 2006 10:13 pm
CAMB01 wrote:what i thought you meant was just bolt one cap on then turn and then bolt another cap on.
oh I see, thats not what I ment, all the caps have to be on :D , just as you torque them if the crank goes stiff the starter may not be able to turn the engine over once its all done :lol: Need to drag the car down the road and jump start it (very rangi and not recommended)
AW11 Track Toy
Caveman
Postby crnkin » Wed Nov 29, 2006 12:31 pm
:o Are those new pauter rids? Gimme gimme!
deaf_homo "currrently yes"
crnkin
Postby no_8wire » Wed Nov 29, 2006 12:37 pm
why yes...yes they are...
8)
and no, keep your hands to yourself!
haha
no_8wire
Postby crnkin » Wed Nov 29, 2006 4:34 pm
:( rich bastard
crnkin
