abv mod,
Postby bluemaumau » Mon Feb 19, 2007 8:50 pm
Crampy wrote:
T the line from the fuel pressure reg to the brown VSV and that goes to the ABV and a boost gauge.
thats line "e"
:wink:
cheers for your help crampy
Postby Crampy » Mon Feb 19, 2007 8:52 pm
bluemaumau wrote:looking at the diagram you posted,
your saying "t" the abv and boost guage line at line "e"
i would have thought line "B" would have been correct, thats were my boost guage is currently
Sorry dude man, my bad, I did write that. It's edited to what I was meant to say, to avoid any confusion.
So, yep T to the "B" line on the diagram and you'll be boosting sweet.
Crampy
Postby bluemaumau » Mon Feb 19, 2007 8:55 pm
allgud, thanks dude, ill get cracking tomorrow
next Q: why the $&#$% are those lines blocked? were should they run!
Postby Crampy » Mon Feb 19, 2007 8:56 pm
bluemaumau wrote:allgud, thanks dude, ill get cracking tomorrow
That's a good question dude, but I can't make them out very well on the pic.
Crampy
Postby Crampy » Mon Feb 19, 2007 9:01 pm
On closer inspection, those two long lines that are blocked to to be the cold start air lines. The lines below on the same piece are the water lines for the cold start mechanism. I ended up just getting rid of all of that $hit on my AW. It broke and was too hard to get a replacement, so I just didn't have proper cold start. All it meant was I had to hold a bit of throttle until it warmed up a bit, or else it would stall. not a biggie as these thing need to be warmed up anyway, cause of the forged pistons slapping away when they're cold.
Crampy
Postby bluemaumau » Mon Feb 19, 2007 9:03 pm
o ok were should they be connected to? i cant find anywere! maybe something else thats been broken and stripped out
double post :?
Postby escortman » Mon Feb 19, 2007 9:04 pm
on mine those are joint by one line lol mayb thats y its a bit ruf on start up
4x4 toyota blizzard offroader
escortman
Postby thegreatestben » Mon Feb 19, 2007 10:07 pm
Dunno if this helps or not.
thegreatestben
Postby Crampy » Mon Feb 19, 2007 11:20 pm
That's a good pic for the factory vacuum lines, but not for these chaps that are going for bigger boost.
The other cold start lines are not on that diagram, as they are on the other side of the throttle body.
Yeah Escortman, I'd say that could be why it's not so good on startup. Either that, or cause you don't have a brown VSV. Might have to research what the brown VSV actually does. Something to do with fuel pressure???
I wouldn't bother with doing anything about the cold start. It just means you have to be gentle with it when cold. You should be warming it right up anyway. Forged pistons slap around a bit until they are warmed up.
Crampy
Postby Crampy » Mon Feb 19, 2007 11:24 pm
bluemaumau wrote:o ok were should they be connected to? i cant find anywere! maybe something else thats been broken and stripped out
Now from memory, in my AW those lines went to the side of the engine bay, under the intercooler. They were connected to a VSV of sorts. Not sure how it's controlled though.
Crampy
Postby matt dunn » Mon Feb 19, 2007 11:25 pm
Crampy wrote:Might have to research what the brown VSV actually does. Something to do with fuel pressure???
The brown VSV stops vacuum acting on the fuel regulator while cranking, to increase fuel pressure for hot start enrichment.
Matt
Postby Crampy » Tue Feb 20, 2007 10:52 am
Matt
Sweet, cheers Matt.
So, I'd say Escortman's problems when cold is because of that cold start setup.
Crampy
Postby escortman » Tue Feb 20, 2007 10:02 pm
must be, just runs a bit ruff, is it doing any damage
so is there anyone that could take a look at my setup and be able to point me in the right direction
escortman
Postby Crampy » Tue Feb 20, 2007 10:48 pm
escortman wrote:must be, just runs a bit ruff, is it doing any damage
I can have a look if you want. I'm based out on the Air Force base in Whenuapai. It's not too far away from where you are. I bought that AE92 parcel tray off ya if you remember that.
What do you want checked? The ABV mod, or the cold start, or just everyting in general? I can get the ABV mod done sweet as, but with your conversion, you might find you wont be able to get the cold start going properly. Depends if you can find the bits and where the connect to.
Sweet.
Crampy
Postby escortman » Tue Feb 20, 2007 10:51 pm
o yeh thats rite
na not worried about cold start more the abv mod, wat times u free?
escortman
Postby Crampy » Tue Feb 20, 2007 11:48 pm
Sweet, let's get this b*tch boosting then 8)
I'm on night shifts at the moment. Start is 4PM, til late (at work at the moment :cry: )
I'll be working on my cars tomorrow on Base, so if you can make it there before 4 PM, I'll be able to have a look see.
My cell is 027 291 0955. Gimme a text if you're able to come.
PS, You'll probably need a T and maybe some vacuum hose and something to block other lines, depending on how you're car is set up now.
Crampy
Postby escortman » Wed Feb 21, 2007 12:06 am
na i dnt finish til 4.30 and based out at neilson st in onehunga, mayb on the w/e if u arnt busy?
escortman
Postby Crampy » Wed Feb 21, 2007 10:51 am
Sweet as.
I'm on call over the weekend, so wont be going anywhere.
So, come over sometime on Saturday.
Crampy
