thats line "e"Crampy wrote:
T the line from the fuel pressure reg to the brown VSV and that goes to the ABV and a boost gauge.
cheers for your help crampy
bluemaumau wrote:looking at the diagram you posted,
your saying "t" the abv and boost guage line at line "e"
i would have thought line "B" would have been correct, thats were my boost guage is currently
bluemaumau wrote:allgud, thanks dude, ill get cracking tomorrow
next Q: why the $&#$% are those lines blocked? were should they run!
bluemaumau wrote:o ok were should they be connected to? i cant find anywere! maybe something else thats been broken and stripped out
Crampy wrote:Might have to research what the brown VSV actually does. Something to do with fuel pressure???
matt dunn wrote:Crampy wrote:Might have to research what the brown VSV actually does. Something to do with fuel pressure???
The brown VSV stops vacuum acting on the fuel regulator while cranking, to increase fuel pressure for hot start enrichment.
Matt
escortman wrote:must be, just runs a bit ruff, is it doing any damage
so is there anyone that could take a look at my setup and be able to point me in the right direction
