MAGN1T wrote:Maybe you're using a "fake" chineese made voltmeter?
MR2SIK wrote:MAGN1T wrote:Maybe you're using a "fake" chineese made voltmeter?
http://file034a.bebo.com/9/large/2007/06/10/03/18613059a4635439204l.jpg
doesnt look overly fake or chinese to me
JRS wrote:but it's not as accurate as a real voltmeter and you can't take measurmets at various points in the charging system for making a diagnosis.
MAGN1T wrote:The check light usually (a generalisation) has the battery voltage at one side, via the ignition switch and the other side of the light goes through the rotor and regulator to earth.So long as the alternator is making voltage(which is also fed to the rotor via diode bridge) , the light won't come on, unless there's a short in the regulator.
Steve
