Too much volts ????
Postby MAGN1T » Thu Jun 19, 2008 11:30 pm
Maybe you're using a "fake" chineese made voltmeter?
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Not enough volts... actually, no volts at all !!!!
Postby jondee86 » Sat Jun 21, 2008 8:25 pm
Went to start the car today, and the battery was flatter than... a really
flat thing :( Pulled the alternator out and according to my amateurish
testing, there is at least one diode that gives the same reading with
either polarity.
I figure it has shorted and allowed the electricity to leak out of the
battery while it has been sitting. Same thing probably caused the higher
than usual voltage while charging.
Anyways, its either repair or replace the alternator time :-| Just hope
it hasn't killed the battery. If it has, is that covered by the battery
warranty ?? It is only about 6 months old and a quality NZ made item.
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby MR2SIK » Sun Jun 22, 2008 1:06 am
MAGN1T wrote:Maybe you're using a "fake" chineese made voltmeter?
http://file034a.bebo.com/9/large/2007/06/10/03/18613059a4635439204l.jpg
doesnt look overly fake or chinese to me
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby rollaholic » Sun Jun 22, 2008 9:45 am
just dont tell them the battery died because your alt shit itself. i've never really been asked too many questions when i take batteries back at work.
Postby MAGN1T » Sun Jun 22, 2008 12:18 pm
That's NOT a voltmeter.
That's an overly expensive black box that underperforms the thing that was there beforehand.
You can't beat the real thing.
Steve
MAGN1T
Postby cat007 » Sun Jun 22, 2008 12:29 pm
I'm not sure what we're looking at?
Postby Alex B » Sun Jun 22, 2008 2:16 pm
Me thinks the link would give you a voltage readout.
Postby JRS » Sun Jun 22, 2008 3:32 pm
but it's not as accurate as a real voltmeter and you can't take measurmets at various points in the charging system for making a diagnosis.
meh.....
JRS
Postby matt dunn » Sun Jun 22, 2008 8:16 pm
JRS wrote:but it's not as accurate as a real voltmeter and you can't take measurmets at various points in the charging system for making a diagnosis.
correct, as it only reads voltage at the ECU,
but if you are getting 15V at the ecu,
then there is only going to be higher voltage than that at the alternator, not lower.
Postby MAGN1T » Sun Jun 22, 2008 11:15 pm
Unless the link has had the software fudged to reduce the error. All computers tell lies.
It's not hard to check the voltage the proper way.
The check light usually (a generalisation) has the battery voltage at one side, via the ignition switch and the other side of the light goes through the rotor and regulator to earth.So long as the alternator is making voltage(which is also fed to the rotor via diode bridge) , the light won't come on, unless there's a short in the regulator.
Steve
MAGN1T
Postby matt dunn » Mon Jun 23, 2008 12:05 am
MAGN1T wrote:The check light usually (a generalisation) has the battery voltage at one side, via the ignition switch and the other side of the light goes through the rotor and regulator to earth.So long as the alternator is making voltage(which is also fed to the rotor via diode bridge) , the light won't come on, unless there's a short in the regulator.
Steve
Not in a toyota alternator, as one side of the brush holder is permanently connected to BATT + supply inside the alt.
The light is switched off electronicaly by the regulator by correct voltage on the sensing wire, and buy AC pulse to the stator terminal on the regulator.
There are no exciter diodes in them, just 8 main diodes.
