power steering
ps
Postby fxgt race » Thu May 21, 2009 11:42 pm
After hours i found a site,yes loop the feeds,leave some fluid in to keep it lubed,T a breather into it somewhere,haven't had a chance to inspect where but will get on to it on the weekend,The breather allows the air in the rack to move around easiler So the driver doesn't,will fit a larger steering as well
Pukekohe 1.07.6
Taupo 1.41.3
Manfield 1.18.7
hamptondowns 1.15.2
fxgt race
Re: ps
Postby matt dunn » Fri May 22, 2009 12:02 am
fxgt race wrote:After hours i found a site,yes loop the feeds,leave some fluid in to keep it lubed,T a breather into it somewhere,haven't had a chance to inspect where but will get on to it on the weekend,The breather allows the fluid to move around easiler So the driver doesn't,will fit a larger steering as well
Yeah that's pretty much the go.
gotta leave a bit of fluid in there to keep it all lubed up.
Postby Crampy » Wed May 27, 2009 6:48 pm
http://www.trademe.co.nz/Trade-Me-Motor ... 929859.htm
Found this on Tardme. Dunno if you'd be interested, but someone here might be.
Crampy
Postby Maxwedge » Wed May 27, 2009 8:10 pm
I run a FXGT rally car, I have a PS rack (original FXGT AE82) which I run a looped hose topped up with fluid and a smaller wheel. I have plenty of feel and it is predictable to drive. But its a little harder at slow speeds. it has 3 turns lock to lock.
You can pick up a Superstrut rack (AE111 & AE101)and fit AE82 arms to it to achieve a 2.6 rack (2.6 turns lock to lock) but you would have to run the pump. Same setup as the rack listed in the trademe ad in the above post.
Maxwedge
quick rack
Postby fxgt race » Wed May 27, 2009 8:23 pm
Dam Crampy
You have made me buy more stuff,have purchased the rack,Have just had made new rear 40mm bilsteins made to replace the old little ones which were stuffed.It never stops. Trying car without ps this weekend at puke to see what its like
Pukekohe 1.07.6
Taupo 1.41.3
Manfield 1.18.7
hamptondowns 1.15.2
fxgt race
Re: quick rack
Postby Crampy » Thu May 28, 2009 8:41 pm
fxgt race wrote:Dam Crampy
Ha ha, you're welcome :D
Crampy
Postby CelicaGT8 » Tue Jun 02, 2009 4:09 pm
Its awful without ps on the track, especaly in a gt4
CelicaGT8
Postby Bazda » Tue Jun 02, 2009 5:30 pm
I think I saw you out on the track Yesterday..... how did non PS go..
power steering
Postby fxgt race » Tue Jun 02, 2009 9:56 pm
Pretty heavy,will put the quicker rack in an put the ps back.When it comes to ss 2000 racing and how quick sometimes you need to change direction to get around other competitors i will need it,Had problems with the new close ratio gearbox ,after 3 laps had problems getting 3,4th gear,5th no problems.Have you had a look at your motor yet.
Pukekohe 1.07.6
Taupo 1.41.3
Manfield 1.18.7
hamptondowns 1.15.2
fxgt race
Re: power steering
Postby Crampy » Tue Jun 02, 2009 10:35 pm
fxgt race wrote:Pretty heavy,will put the quicker rack in an put the ps back.When it comes to ss 2000 racing and how quick sometimes you need to change direction to get around other competitors i will need it,Had problems with the new close ratio gearbox ,after 3 laps had problems getting 3,4th gear,5th no problems.Have you had a look at your motor yet.
Let me know how that rack goes. I might look into something like that later down the track when I've got my car going.
Crampy
