fxgt race wrote:After hours i found a site,yes loop the feeds,leave some fluid in to keep it lubed,T a breather into it somewhere,haven't had a chance to inspect where but will get on to it on the weekend,The breather allows the fluid to move around easiler So the driver doesn't,will fit a larger steering as well
fxgt race wrote:Dam Crampy
You have made me buy more stuff,have purchased the rack,Have just had made new rear 40mm bilsteins made to replace the old little ones which were stuffed.It never stops. Trying car without ps this weekend at puke to see what its like
fxgt race wrote:Pretty heavy,will put the quicker rack in an put the ps back.When it comes to ss 2000 racing and how quick sometimes you need to change direction to get around other competitors i will need it,Had problems with the new close ratio gearbox ,after 3 laps had problems getting 3,4th gear,5th no problems.Have you had a look at your motor yet.
