Rust prevention - Fish oil etc.
Postby mjrstar » Mon Aug 10, 2009 10:48 pm
who cares about the rust prevention, 1g details please.
fyi dinitrol is pretty good stuff for rust prevention, my por15 didn't work too flash.. it doesn't like UV rays..
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby dirty1 » Tue Aug 11, 2009 3:19 pm
Have you thought about using industrial/marine grade products?
Altex Coatings (where i work) have a couple of different options.
single pack version - RIPO(rust inhibiting protective oil)
http://www.altexcoatings.co.nz/vdb/document/417
thin penetrating liquid for use in Interior of doors and panels etc.
$28.50 per litre = about 30SQ/M per litre
or:
two pack version - Altra Lock 577 (rust and crevice sealer)
http://www.altexcoatings.co.nz/vdb/document/413
penetrates surface rust , crevices, plate laps etc.
3 to 1 mix ratio
$48 per 1L kit = about 33 SQ/m per litre
both can be (and really should be) top coated, ripo with High build rust barrier.
577 with altra shield2000 or Altra build 536
check the Altex website for more info.
2005 GRS180 Crown Royal 2.5L (4GR-FSE) V6
1997 ST195 Caldina TZ-G Aerial (3S-GE)
1988 AE92 Rolla FX-GT (4A-GE) (gone, but not forgotten)
dirty1
Postby GTCRSHR » Tue Aug 11, 2009 5:15 pm
mjrstar wrote: my por15 didn't work too flash.. it doesn't like UV rays..
you are suppose to paint over the top
Nothing to see here ...
GTCRSHR
Postby Bling » Tue Aug 11, 2009 5:23 pm
Yeah POR15 works perfectly if you use it correctly.
Anything other than proper use and its no better than any other product. Thats why unless you can make sure the surfaces are clean etc I wouldn't bother using it in hard to get to places. If you can clean/prep the surface, its great.
Postby 2LTR Rona » Tue Aug 11, 2009 5:26 pm
Product I have used many times over with very good results is Blackguard.
Can be brushed on, rolled on or sprayed on
I opted for the brush on option, left to dry and then primed straight over the top
more details H E R E
2002 Altezza, 1974 KE25
2LTR Rona
Postby t0ms » Tue Aug 11, 2009 6:19 pm
Wurth make a product called "cavity protection spray" which is the yellowy waxy stuff manufacturers use when they build cars
could get a can or two of that and go to town on the hidden areas which will seal them off
t0ms
Postby B1NZ » Tue Aug 11, 2009 6:32 pm
sergei wrote:That product is called Tectyl. It is nasty to apply - very sticky but does not smell like unwashed penis.
It is made by Valvoline and sold in NZ.
Arrgh, thats the stuff that is crap, it dries out and cracks, moisture gets in the cracks and rusts from my experience.
A smelly car is a small price to pay for a lifetime of non rustyness imo
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Dell'Orto » Tue Aug 11, 2009 6:49 pm
Nah I dunno man, my sedan was tectyl'd to hell, and it was one of the least rusty KE70's I'd seen.
Postby Mr Revhead » Tue Aug 11, 2009 6:59 pm
t0ms wrote:Wurth make a product called "cavity protection spray" which is the yellowy waxy stuff manufacturers use when they build cars
yeah i'v used that
it's also what toyota specify for spraying on hilux decks that get tray liners.
some of you are forgetting what this poster is doing.
Postby mr30%jr » Wed Aug 12, 2009 12:14 am
and cost 10 million dollars a litre
mr30%jr
