1998 KZN185 3L I/C TD Surf - cooling stuff
Postby strx7 » Tue Mar 08, 2011 3:57 pm
what was the water pump last done? does it always run with antifreeze/corrosion inhibitor? how long have you had the vehicle?
Postby Boosted_162 » Tue Mar 08, 2011 5:36 pm
strx7 wrote:what was the water pump last done? does it always run with antifreeze/corrosion inhibitor? how long have you had the vehicle?
No idea on pump, has run antifreeze since ive had it, only had it 2 or so months, and my mate owned 4 months beforehand and its always done it.
Postby strx7 » Tue Mar 08, 2011 7:18 pm
i'd be looking at the water pump
Postby Boosted_162 » Tue Mar 08, 2011 10:29 pm
strx7 wrote:i'd be looking at the water pump
Awesome, pump is easier than pulling the head off!
Thanks heaps :)
Postby Santa'sBoostinSleigh » Fri Mar 11, 2011 8:53 am
brought a large trans cooler yesterday, and will hopefully be fitting it this weekend,
might do a bit of a photo sesson while i am at it
currently I am erring on the side of bypassing the factory cooler in the radiator totally, and maybe even looking at getting a manual radiator installed or an aftermarket alloy one in the future
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Santa'sBoostinSleigh » Sat Mar 19, 2011 11:01 pm
trans cooler in in, plumbed in series with factory cooler as recommended on the instruction booklet
also gave the surf an engine flush and oil change, and tightened the belts as they were a bit on the loose side
towing to Masterton today with a Valliant drag tank on the trailer, and 4 of us plus gear in the back, its still getting warm going up long hills...
next step ali radiator? or maybe look at replacing the viscous fan?
Santa's Mega Sale
Postby Bling » Sat Mar 19, 2011 11:46 pm
Sounds like its towing a fair load so maybe its just pushing it a bit hard?
I have no idea tbh, but would an oil cooler help things? Other than that I think you need a small truck as I doubt a surf is designed with that much of a beating in mind :lol:
Postby strx7 » Sun Mar 20, 2011 8:53 am
it should already have an alloy radiator. if it has a brass one that could be the issue.
Postby Santa'sBoostinSleigh » Mon Mar 21, 2011 9:00 am
when i say that i mean one of those big aftermarket ones
i believe this is a twin core one now
Santa's Mega Sale
Postby 85AW20v » Mon Mar 21, 2011 9:59 pm
85AW20v wrote:Take the radiator out and get it cleaned properly at a radiator specialist - tanks off, rodded through and reassembled.
Done this part yet?
See ya
Simon
85 MR2 20v
85AW20v
Postby Santa'sBoostinSleigh » Tue Mar 22, 2011 9:58 am
getting the radiator 'serviced' is most likely going to cost as much as a replacement one
i have read up on some aussie forums and its looking like the viscous fan is getting buggered and not cooling efficiently. unfortunately this is an expensive fix, but sounds like its problem solved when a new one is fitted
Santa's Mega Sale
Postby allencr » Tue Mar 22, 2011 7:41 pm
Look at the tops of the core tubes, the 6-10 that are visible gives a good indication of all the others. If more then a few, 2-3, are clogged or have a heavy mineral buildup that'll restrict flow, then it needs cleaning.
The fan is useless & does nothing for engine cooling, except restrict airflow, at any speed over 25kph so that isn't your problem unless it's overheating when sitting still.
Is all the airflow going through the radiator, without any big gaps or panels removed that allow it to bypass the radiator?
allencr
Postby Dell'Orto » Tue Mar 22, 2011 8:27 pm
Santa'sBoostinSleigh wrote:getting the radiator 'serviced' is most likely going to cost as much as a replacement one
Shit no, wouldnt expect a clean to run much over $100
Postby matt dunn » Tue Mar 22, 2011 10:18 pm
We have had one off a 1KZTE surf sent away and re-viscoused ??? lol
They pulled it apart and replaces the fluid or whatever in it.
When dead cold and you start the engine it should be noisy(fan blade noise) for a few seconds before they go quiet.
Postby MAGN1T » Wed Mar 23, 2011 11:43 am
allencr wrote:Look at the tops of the core tubes, the 6-10 that are visible gives a good indication of all the others. If more then a few, 2-3, are clogged or have a heavy mineral buildup that'll restrict flow, then it needs cleaning.
So long as it's always had antifreeze in it, the cooling system won't be clogged. They only get clogged after a leak and the owner tops it up with water , that causes corrosion in the cooling system then clogging. If it needs topping up then it's got a leak, either internal or external.
No, the fan does nothing when it's moving.
My turbo diesel hilux has only ever got hot once, that was towing a car up the wainui hill with a tailwind. No it doesn't have a working fan.
Towing 600Kgs isn't a lot. A car trailer and car comes in at about 2200Kgs which I've done a return trip to Taupo with (towing with hilux) and no overheating and no fan.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby Mr Revhead » Wed Mar 23, 2011 1:14 pm
You can buy the fluid from Toyota in a small bottle.
Postby strx7 » Wed Mar 23, 2011 1:40 pm
just drill a hole thru it and put a nail in it, direct drive fan.
Postby matt dunn » Wed Mar 23, 2011 6:46 pm
strx7 wrote:just drill a hole thru it and put a nail in it, direct drive fan.
All good for everything except fuel economy and noise.
Postby strx7 » Wed Mar 23, 2011 8:54 pm
it was one of the many rangi fixes i've seen come thru the doors
Postby DFECTED » Mon Mar 28, 2011 9:40 am
just had a super custom doing the same thing, changed the thermostat, fixed
DFECTED
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
