I re-drill discs all the time with my Wilwood conversions.
Never had any issues. For me drilling is pretty quick via a CNC and milling cutter.
I would rather drill than to slot the holes.
Using a drill would take 10x longer!
wde_bdy wrote:Most discs are fine to redrill, but given there are already 17 holes in that disc I personally wouldn't want to add another 5 to it.
Callum
RomanV wrote:About you not being able to cert with two spacers, is that a spacer for the disc and spacer for the caliper?
Not allowed both?
Or did you have two spacers for the disk itself somehow...
Bazda wrote:I recon the engineer doesn't want to do it as he isnt gona be able to charge enough to make it even worth while.
loudstealthGT-Four wrote:Bazda wrote:I recon the engineer doesn't want to do it as he isnt gona be able to charge enough to make it even worth while.
Haha, na I had a few other things for him to do as well, but just told him I would take them somewhere else.
If I'd have known how much hassle and $$$ this brake conversion was going to be I would have just bought a kit off you
