PRYMORTAL wrote:Hmm just a guess - have u tryed cheaking out to see if theres any water in your radiator?
PRYMORTAL wrote:carbys piss otu white smoke from the exhuast with no water in radiator we found a while ago with my mates car, also jeff had white smoke and said it was his valve seals? dunno one that 1 tho
All_Fours wrote:white smoke is means you are getting water/coolant into the cylinders, usually by way of blown head gasket or cracked head etc.
I should note, however, that practically all cars blow white smoke when cold, and if it goes away after a few minutes then it's nothing to worry about
Oh yeah, are you sure it's just white, or white with a bit of blue in it? if it's the later then that's oil burning, either seeping through the rings or coming through the valve seals.
4AGE 8U wrote:does it smoke after ur've given it a bit of sh!t? cos on my car it blew white smoke after a thrashing and it was the valve stem seals, wat kinda oil ya running? cos if the oil is too thin it just leak through the valves after the oil is hot.
