White smoke?
White smoke?
Postby skoty » Wed Mar 24, 2004 11:47 pm
Ok, got my 2E ( 1300 12v carby ) running properly after following the 'process of elimination theory' So the cars running mint right, but its dumping sh*t loads of white smoke :? What does this mean?
skoty
Postby PRYMORTAL » Thu Mar 25, 2004 1:27 pm
Hmm just a guess - have u tryed cheaking out to see if theres any water in your radiator?
PRYMORTAL
Re: 1
Postby Banga69 » Thu Mar 25, 2004 2:04 pm
PRYMORTAL wrote:Hmm just a guess - have u tryed cheaking out to see if theres any water in your radiator?
arr didnt he say white smoke, not steam.
CURRENT:
1994 Mazda Lantis
EX:
SOLD: AE101 GTZ ====>http://toyspeed.blakjak.net/profiles/profile.php?id=89
Banga69
Postby TazzieDevil » Thu Mar 25, 2004 2:14 pm
Someone mentioned to me - Spark plugs needed changing, when i was getting white smoke (assuming you mean outta the exhaust)
Hoep that helps.
Get In, Sit Down, Shut Up & Hold On
TS Profile
It wasn't Me, it was the one armed Man!
TazzieDevil
1
Postby PRYMORTAL » Thu Mar 25, 2004 6:25 pm
carbys piss otu white smoke from the exhuast with no water in radiator we found a while ago with my mates car, also jeff had white smoke and said it was his valve seals? dunno one that 1 tho
PRYMORTAL
Postby Malcolm » Thu Mar 25, 2004 7:28 pm
white smoke is means you are getting water/coolant into the cylinders, usually by way of blown head gasket or cracked head etc.
I should note, however, that practically all cars blow white smoke when cold, and if it goes away after a few minutes then it's nothing to worry about
Oh yeah, are you sure it's just white, or white with a bit of blue in it? if it's the later then that's oil burning, either seeping through the rings or coming through the valve seals.
Postby skoty » Thu Mar 25, 2004 11:34 pm
I was told it means somehow water is getting into the fuel which could mean cracked/warped head, blown head gasket etc...
skoty
Re: 1
Postby skoty » Thu Mar 25, 2004 11:41 pm
PRYMORTAL wrote:carbys piss otu white smoke from the exhuast with no water in radiator we found a while ago with my mates car, also jeff had white smoke and said it was his valve seals? dunno one that 1 tho
The radiator is fine, plenty of water. Worn valve seals/guides usually mean oil is seeping into the combustion chambers and should blow black smoke rather.
skoty
Postby skoty » Thu Mar 25, 2004 11:46 pm
All_Fours wrote:white smoke is means you are getting water/coolant into the cylinders, usually by way of blown head gasket or cracked head etc.
Nope, no blue smoke at all. Thanks for the help anyway Toyspeeders :wink:
skoty
smoke
Postby JasonZE » Sat Mar 27, 2004 9:24 pm
If its not coolant, on some rare occasions a faulty brake master cylinder can seep brake fluid into the manifold through the booster pipe take the pipe off and make sure its dry...
This fault produces white smoke
JasonZE
Real Life Mechanic
Postby 4AGE 8U » Wed Mar 31, 2004 2:17 am
does it smoke after ur've given it a bit of sh!t? cos on my car it blew white smoke after a thrashing and it was the valve stem seals, wat kinda oil ya running? cos if the oil is too thin it just leak through the valves after the oil is hot.
4AGE 8U
Postby skoty » Wed Mar 31, 2004 3:54 pm
4AGE 8U wrote:does it smoke after ur've given it a bit of sh!t? cos on my car it blew white smoke after a thrashing and it was the valve stem seals, wat kinda oil ya running? cos if the oil is too thin it just leak through the valves after the oil is hot.
Its pretty good when idling but as soon as you pack on a few revs (not much) it smokes like a bitch. You reckon the oil could be a bit to thin, never thought of that :wink:
skoty
Postby skoty » Wed Mar 31, 2004 3:59 pm
...I willl try that Jason also, but I'm just assuming as the plugs are covered in oil that either...
-oil rings are worn
-valve guides are worn and/or valve seals
-worn cyclinder bores
blah blah blah, so I was just going to do a complete block & head transplant, is this a silly idea?
skoty
Postby 4ageman » Wed Mar 31, 2004 11:11 pm
Blue smoke is oil black smoke is fuel and white smoke mean's water is some how finding its way into the combustion chamber
4ageman
Postby Pies » Thu Apr 01, 2004 3:18 pm
well i got the same thing on my AW11. pours out white smoke, but only after about a minute of running. and it smells like burnin oil. no blue in it tho, just a big, pure white, cloud of smokey shit. even AFTER i put a bottle of stp smoke stop in. never thought to check the radiator so i might do that. but still, it smells like oil
i thought it might be rings? but after reading this i might just rebuild the head, althought according to ryan (twolitre - on of the previous owners) the head has just recently been given a freshen up :S so i dunno.
any ideas anyone?
Current Rides:
Pies
Postby 4ageman » Fri Apr 02, 2004 8:16 pm
maybe you have a cracked head and oil is getting into the water would explain the oil smell and the white smoke
4ageman
Postby 2fas4u » Tue Apr 13, 2004 8:17 pm
months ago when i went out cruising with ma car slapper, my car (MR2 sw20 n/a) smoked white exactly like the way you described it. my mate reckoned it was radiator so i spent ages at the petrol station trying to fill up my radiator with water to no success cos it was packed with crap so u took it to rutherford and bond toyota to get it check out it it appeared that my oil dipstick tube was cracked just by the engine and oil was leaking onto the exhaust which is burning it up making the white smoke. costed me $760 to get it all fixed but this included remoulding a new distick tube, oil and oil filter change, flushing of radiator and refilling it with antifreeze coolant. so check under your car for oil leaks.
2fas4u
