can anyone show me in pic where is the bracket...aesc wrote:You just need to unbolt the bracket that holds the sway bar and bush in place, and support the sway bar itself with a jack so it doesnt drop.
Mr Revhead wrote:when takign the links off, soak them in wd40. they have allen key inerts in the ends as often the will spin inside, and you wont be able to shift the nut.
AceSniper wrote:mmm i went through all this just yesterday![]()
rattlegun was no good... just turned the whole thing around in the sleve/bush
a spaner, a alan key with a spaner on the end (leaverage) did the job
when thise are worn whats the visual signs?
i think my problem is the sway bar link, it is suppose to be tight??? cos i check the screw is tight but the link seems to be able to move... how much is the bush on the link???TRDWGN wrote:It won't be the bush, most likely the sway bar link, about 4 or 5inches long, bolts to rear shocks and to rear swaybar...
To replace you just need to take your wheel off to access, real easy, best you have access to a rattle gun though as after a few years of being on there happily they can be a bit of a biarch to take off...
bad20v wrote:.......with a 'correct' sized allen key and a spanner.....
