Clunking from rear suspension in ae111
Postby RAZA » Fri May 07, 2004 10:41 am
Hi all,
anyone know whether there is a common part in the rear suspension of an ae111 levin that would cause a clunking noise going over bumps?
It sounds like a bush has gone somewhere but there are a lot of parts and it only makes the noise when going over bumps, i cant seem to find any parts with play in them while its stopped.
best i can tell its not superstrut (has smaller brake calipers)
any thoughts appreciated
Currently driving:
BMW 135i M
RAZA
Postby aesc » Fri May 07, 2004 11:36 am
Sway bar bushes, common problem with these things.
EX AE101 owner
2013 Ford Focus ST
aesc
Postby RAZA » Fri May 07, 2004 2:18 pm
any idea how much of a job to change?
is there anything in the way of the sway bar or can you take it off to change the bushes while leaving the rest of it pretty well intact?
Currently driving:
BMW 135i M
RAZA
Postby aesc » Fri May 07, 2004 2:55 pm
You just need to unbolt the bracket that holds the sway bar and bush in place, and support the sway bar itself with a jack so it doesnt drop.
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Xavier » Fri Apr 29, 2005 2:41 am
aesc wrote:You just need to unbolt the bracket that holds the sway bar and bush in place, and support the sway bar itself with a jack so it doesnt drop.
can anyone show me in pic where is the bracket... :oops: thanks...
Xavier
Postby TRDWGN » Fri Apr 29, 2005 9:35 am
It won't be the bush, most likely the sway bar link, about 4 or 5inches long, bolts to rear shocks and to rear swaybar...
To replace you just need to take your wheel off to access, real easy, best you have access to a rattle gun though as after a few years of being on there happily they can be a bit of a biarch to take off...
TRDWGN
Postby Bling » Fri Apr 29, 2005 9:48 am
I'm pretty sure mine had this issue and it was the bushes on the swaybar also, didn't fix it myself, but after being shown what was done didn't look too hard to do :)
Postby Mr Revhead » Fri Apr 29, 2005 12:42 pm
when takign the links off, soak them in wd40. they have allen key inerts in the ends as often the will spin inside, and you wont be able to shift the nut.
Postby TRDWGN » Fri Apr 29, 2005 1:06 pm
Mr Revhead wrote:when takign the links off, soak them in wd40. they have allen key inerts in the ends as often the will spin inside, and you wont be able to shift the nut.
Forget the allen keys!! I rooted about three trying, the only way I could get mine off were a dirty big rattle gun, The new ones i got off you had some sort of loc-tite already on them so no doubt it forms a pretty good bond once tightened :lol: hence the issues i had getting the old ones off!!
TRDWGN
Postby AceSniper » Fri Apr 29, 2005 1:13 pm
mmm i went through all this just yesterday :lol:
rattlegun was no good... just turned the whole thing around in the sleve/bush
a spaner, a alan key with a spaner on the end (leaverage ;) ) did the job
when thise are worn whats the visual signs?
AceSniper
Postby TRDWGN » Fri Apr 29, 2005 1:19 pm
AceSniper wrote:mmm i went through all this just yesterday :lol:
Trust me i can show you 3 allen keys that got leverage :lol: they twisted, i had vice grips on the allen key also, mind you i also used a big screw driver to lever between link and sway/shock when rattling them off so it didn't spin
TRDWGN
Postby Xavier » Fri Apr 29, 2005 1:46 pm
TRDWGN wrote:It won't be the bush, most likely the sway bar link, about 4 or 5inches long, bolts to rear shocks and to rear swaybar...
i think my problem is the sway bar link, it is suppose to be tight??? cos i check the screw is tight but the link seems to be able to move... how much is the bush on the link???
Xavier
Postby Mr Revhead » Fri Apr 29, 2005 1:48 pm
yup thats it. TRDWGN you were lucky yours didnt do that!
Postby bad20v » Fri Apr 29, 2005 5:31 pm
Link Link Link Link Link Blink
If the problem is definately the sway bar links then take them off as above, with a 'correct' sized allen key and a spanner. Take the old one down to your local suspension shop and get new ones for both sides, as there is no point doing just one side. If you cant find a shop thats has them then ring SAS on 092623684, they are in Manukau and they definately stock them. ( I used to work there ). Bout $15.00 each.
If that does fix the noise then it will be another bush. Either the rear trailing arm bushes or the 'pillow ball' bushes in the ends of the rear control arms. These can also cause the sounds you have been hearing and are more commonly picked up when you go for a wof because your rear wheels have too much lateral movement.
My best advice, go see SAS and get them to check your car. Tell them the problem and let them sort it out. It wont cost you anything for them to check it out. Then you get get them to do it or you can buy the offening parts and do it yourself.
Greg
Thank-You.
bad20v
Postby TRDWGN » Fri Apr 29, 2005 6:35 pm
bad20v wrote:.......with a 'correct' sized allen key and a spanner.....
:lol: Is that a dig at me? Cos i can assure you i used the right size, i didn't burr the end of the allen key nor the hex slot on the link, no I managed to twist the whole god damn allen key.... my car had had some TRD suspension put in it (most likely when it was new) and i would say they over torqued everything as every bolt on those struts was tight as a mofo and when even I have to use an extension tube on a power bar then she's definitely tight!!!
TRDWGN
Postby Lloyd » Fri Apr 29, 2005 7:14 pm
Check all the control/trailing arm bolts are tight. Had one of mine slightly loose and it sounded bad on bumps. Replced the sway bar bushes and the noise wasn't gone, turned out just to be one slightly loose bolt.
Postby AceSniper » Sat Apr 30, 2005 3:16 am
yea i wasnt far off twisting an snapping the key... used a rattle gun seamed to get the dirt an shit off, then some crc then alot of twisting with the spanner and key, once its loose was easy to wind out... till the end of the therd where is once again jammed tight, I thought id brake the alan key, but I didnt have many ideas or tools sitting near by to try.
AceSniper
Postby B1NZ » Sun May 01, 2005 7:14 pm
Mine was making the same noise from the rear, turned out to be the sway bar bushes, replaced and presto - no noise
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
