distorted wrote:my 96 celica went in 4 a new clutch, and when it finally came out, the little ABS light doesn't turn off. ive had it back into the shop and they have checked the sensors near the wheels, and they have also had an auto electrian, have a look at the wires. but still no go!! has any one ever had the same problem?! any advice would b nice. its going to a ecu specialist tommorow, will this help?
matt dunn wrote:Had a mechanic bring a car in with the same problem a week ago.
they had just done c.v.boots in it.
When they had it to biots they had stretched the abs sensor cable and the wiring inside them is so fine it had broken the cable inside. No visable damage on the outside.
They would have had your axels out may be a similar problem.
I patched the cables and made new wiring from the sensor head the the plug.
Matt
nemesis wrote:you patched saftey critical sensor wiring? Personally I would accept no less than a replacement sensor.
