ABS light
ABS light
Postby distorted » Wed Jun 23, 2004 6:56 pm
my 96 celica went in 4 a new clutch, and when it finally came out, the little ABS light doesn't turn off. ive had it back into the shop and they have checked the sensors near the wheels, and they have also had an auto electrian, have a look at the wires. but still no go!! has any one ever had the same problem?! any advice would b nice. its going to a ecu specialist tommorow, will this help?
distorted
Re: ABS light
Postby matt dunn » Wed Jun 23, 2004 7:55 pm
distorted wrote:my 96 celica went in 4 a new clutch, and when it finally came out, the little ABS light doesn't turn off. ive had it back into the shop and they have checked the sensors near the wheels, and they have also had an auto electrian, have a look at the wires. but still no go!! has any one ever had the same problem?! any advice would b nice. its going to a ecu specialist tommorow, will this help?
Had a mechanic bring a car in with the same problem a week ago.
they had just done c.v.boots in it.
When they had it to biots they had stretched the abs sensor cable and the wiring inside them is so fine it had broken the cable inside. No visable damage on the outside.
They would have had your axels out may be a similar problem.
I patched the cables and made new wiring from the sensor head the the plug.
Matt
Postby Ae92typeX » Thu Jun 24, 2004 10:31 am
does the box have a speed sensor for the asb at all?. My supra does. Just thinking if it did maybe it wasnt reconnected/or damaged with your clutch change?
Ae92typeX
Re: ABS light
Postby anthonym » Thu Jun 24, 2004 11:56 am
matt dunn wrote:Had a mechanic bring a car in with the same problem a week ago.
I would agree with this diagnosis, I had the same problem with my Altezza (my fault).
Matt
8O you patched saftey critical sensor wiring? Personally I would accept no less than a replacement sensor.
anthonym
Re: ABS light
Postby matt dunn » Thu Jun 24, 2004 8:44 pm
nemesis wrote:8O you patched saftey critical sensor wiring? Personally I would accept no less than a replacement sensor.
Patched may not be the right word.
I ( qualified auto elec) carefully replced the damaged wiring inside the abs sensor lead.
And at the end of the day I have to do what the customer ( person who pays) wants.
Postby 10k 20v » Fri Jun 25, 2004 9:06 pm
also just a note, i have heard of abs sensors becoming faulty when people undo ball joints. The shock from the hammer hitting the hub can upset them.
I'd be putting my money on "matt dunn" diagnosis first.
How did your auto sparky check the sensors?
10k 20v
Postby distorted » Sun Jun 27, 2004 8:40 pm
well the mechanic sent it to his sparky, and he checked the wires all the way from the sensors to the computer, and he couldnt find any wire damage, but i dnt know how well he actually checked them! but yeh still wasnt been to a computer specilist, cos the guy didnt have the right adaptor! so he getting one sent in, then hopefully he can find the problem!!
damn tht bright ABS light at nite!!! just so annoying!
distorted
Postby Adamal » Sun Jun 27, 2004 9:07 pm
Take out the bulb? :D
(Disclaimer: This is a joke and not intended to be taken seriously! (Disclaimer with a Disclaimer: This disclaimer is not intended at distorted, but anyone else out there who might read this and think "Hey, that might dun be a good ideya! Hyuk!" or something along those lines))
Postby rollaholic » Wed Jun 30, 2004 7:25 pm
cant comment on your specific car, however - a lot of euros "store" trouble codes, so for example if they removed an ABS sensor while doing your clutch (possible) then turned the car on without reconnecting it, ECU sees ABS problem. reconnecting the sensor may or may not clear the fault light - many VWs, volvos, saabs etc have to have it cleared by a scanner/diagnostics machine.
