coilovers 4 levins???
Postby levinwreck » Fri Jul 09, 2004 7:39 pm
i want to upgrade my suspension cos the standard shit is kinda buggered. i have king springs and thought about getting new shocks. but i was woundering how much a coilover kit would cost and where can i get one from. also do you need a cert if you get custon shocks/struts??
Ae92 Toyota Trueno GT-Z - STILL GOING
Ae101 Toyota Levin 20V - GONE
78 Lancer - 2BWLAGE
levinwreck
Postby qik20v » Sat Jul 10, 2004 6:48 pm
yea you will need a cert
and adjustables will cost you alot of money, the cheapest/best set i found new are 2000 from sas suspension. they can adjust where the spring and the platform meet, and also where the shock bolts onto the hub can be adjusted down to allow for more travel when the car is very low.
but as i said new adjustables are expensive and all adjustables need a cert ($350)
1996 AE111 Toyota Levin BZ-G - 15.1 @ 146km
http://toyspeed.blakjak.net/profiles/profile.php?id=301
qik20v
Postby Bazda » Sat Jul 10, 2004 11:13 pm
or if u dont want to spend all tha tmoney and keep your king springs just buy shocks that fit your car that have adjustable hardneses.
GAB make them for ae series, monroe, koni and many more, think it's a bit cheaper that way and you wont need a cert.
Postby levinwreck » Sun Jul 11, 2004 3:30 pm
so you dont need a cert for adjustable stiffness but you need one for adjustable hieght???? that might be the way to go also are they the shocks that slot into the original struts or do you need custom struts???
78 Lancer - 2BWLAGE
levinwreck
Postby Bazda » Sun Jul 11, 2004 5:54 pm
I presume your car is a gtz levin.
For the front of the car you can either buy ones that slot in or buy ones that are made with the whole strut.
For the rear you have to buy ones made with the whole strut on it.
No cert needed for adjustable stiffness. Only for height.
Postby TRDWGN » Sun Jul 11, 2004 8:10 pm
Time to contact elliot7 on here for some beautiful TOKICO adjustables, he can do the hell deals :lol: :lol: :lol:
TOKICO make all TRD shocks so you can be rest assured they are good 8) , and half the price of a Koni :wink:
TRDWGN
Postby TRD Man » Mon Jul 12, 2004 10:11 am
A common misconception. TOKICO do make some TRD shocks.
That doesn't mean that a TOKICO brand shock is the same as a TRD shock.
TRD Man
