How does auto react to more power ??
Postby jondee86 » Sat Jul 31, 2004 11:20 am
Does anyone have any first hand experience with ugrading the engine performance on an automatic car ?? For example, if you upped the power on an auto Soarer from 200 hp to 300 hp, how does the auto react to the increased power ??
Here I am talking about a reasonably late model car that will certainly have some degree of electronic control, probably from the engine ECU. Will the box still shift normally at about the same revs if you put more load on it ??
Any auto gearbox technicians out there :?:
Cheers....
jondee86
Watch this space >>> <<<
jondee86
well
Postby TRDmod » Sat Jul 31, 2004 5:23 pm
im not a technician,
but in america when they power up autos, they have aftermarket torque converters etc
Domino's Pizza.....
TRDmod
Postby jondee86 » Sun Aug 01, 2004 12:14 am
Yeah.... good point. Not that I ever looked inside an auto box, but I figure that bigger engines will need bigger torque converters. Wonder how much margin there is on a standard converter ??
I'm thinking that there must be signals going from the ECU to the box telling it when to change based on engine rpm and load.
So, since throttle opening and engine revs would be similar on the 200 hp and 300 hp engines (at full power), maybe the box would shift normally....
Has anyone put NOS on or turbo'd an auto ??
Cheers...
jondee86
jondee86
Postby Rollux » Mon Aug 02, 2004 1:23 pm
Give me 6 months and I'll tell you if mine is still together! :lol:
I have an SR20DET powered Avenir (factory), auto that I plan on screwing another 50 hp or so outta, making about a 20-25% increase. I don't think that will make too much difference to the box.
If it does, I'll let ya know!
2002 Allex RS180 6 Speed
Racing a Honda is like competing in the Special Olympics. Even if you win, you are still a Retard.
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Oversteer is when the Passenger is scared. Understeer is when the Driver is scared
Rollux
Postby deaf_rattle » Mon Aug 02, 2004 1:25 pm
i have a 7mgte auto and will be running more power than stock, i dont imagine running into any problems with the stock box
