Looking to purchase a 3sgte....
Postby WALT3R » Fri Aug 13, 2004 11:30 pm
Hey guys. I have a 1990 celica gt4 group a. Its shit itself big time. Iv been advised to look for anotha engine (its the big ends, will work out cheaper in the long run to get a new engine). Does anybody know of any up for grabs????? Turbo, intercooled, E-ST185H-BLI1NZ, 3SGTE. I am based in rotorua, but im sure freight will not be a problem so yeh, location is not an issue. I will need some sort of certification that shes a good'un, as you will understand. Thanks a lot. If u can find me sumthing that ends up worthwhile a box ov beers is in it for you. 8)
Why do babies shit themselves?.... sometimes you just dont know any better
WALT3R
Postby Chickenman » Sat Aug 14, 2004 2:12 am
If it's just the bigends... surely you could get that fixed for less than the $1300 to $2500 you're gonna have to pay for a new engine? regardless of what you do the labour will be about the same.... good excuse to get the internals upgraded or just replaced as all gen II's are getting on now and whatever you get could succumb to the same problem leaving you $&#$%. So unless something has smashed the block up or made gouges where there shouldn't be gouges.... repair the old one(you also get a lovely warranty thingy) but if you do need 'nother one Mr Revhead is real connected and goodly in prices too.
Baby Jesus
Chickenman
I Am The Walrus!
Postby Rollux » Sat Aug 14, 2004 11:02 am
I'd see it as a perfect excuse to throw a set of forgies in it and get it all nicely balanced. As chickenman said, you get a warranty, and you basically have a brand new engine, not another old one that could sh*t itself in a years time.
2002 Allex RS180 6 Speed
Racing a Honda is like competing in the Special Olympics. Even if you win, you are still a Retard.
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Oversteer is when the Passenger is scared. Understeer is when the Driver is scared
Rollux
Postby WALT3R » Sat Aug 14, 2004 2:43 pm
the bigends have gone in such a way that a piston is smaking the cylinder head. i could get it repaired for the same amount as a new engine, but then theres the ongoing problems, eg oil pump... it goes on and on, the little things. Cameron from A head cylinder head specialists (probly the most on to it chap in roto) said my best bet is a new engine and recondition it. will be back on the road quicker as well.... and my friend? forged pistons are in practically every car these days, i think these engines are forged standard. if ur upgrading pistons? TITANIUM is the one haha.
WALT3R
Postby Al » Sat Aug 14, 2004 11:23 pm
3sgtes dont have forged pistons standard, they are cast.
They do have forged rods and crank tho, near bulletproof once cleaned up.
Al
Postby flygt4 » Sun Aug 15, 2004 2:35 pm
hav u considered upgrading to a gen 3 engine? if u didnt wanna fork for a rebuild etc then could be an option...buy the engine+ecu and ud be sussed.. has the advantage of the bigger turbo , better intercooler etc.also being newer u have more chance of getting one in good condition.gen 2 3sgte's are getting on a bit now.
flygt4
Postby Malcolm » Sun Aug 15, 2004 7:09 pm
WALT3R wrote:the bigends have gone in such a way that a piston is smaking the cylinder head.
ahahaha
How do the bigends go in such a way that the piston is smacking the cylinder head? Did you take the sump off and loosen the bearing caps or something? or has the whole conrod or crank distorted so much that the stroke has increased a few mm?
and no, forged pistons aren't in practically every car, and even if they were your car is still 14 years old which hardly puts it in the bracket of "these days"
Postby WALT3R » Sun Aug 15, 2004 7:10 pm
Iv talked to a chap about that. It will fit, but there will be a hundred million little things that you have to change, waaaay too much $&#$% around. sound advice for anyone upgrading an engine, instead of putting a newer engine in, just buy the newer car. so nobody can help me with an actual engine? iv found a few, but looking for the best mileage, waranty, price....
WALT3R
Postby Al » Sun Aug 15, 2004 7:42 pm
Did you contact Warwick, Mr Revhead like advised?
If he cant find you one, you're shit out of luck.
Al
Postby Chickenman » Mon Aug 16, 2004 5:35 pm
Al wrote:Did you contact Warwick, Mr Revhead like advised?
If he cant find you one, you're sh*t out of luck.
Al: Keepin' it real in the '04 :P Image
Baby Jesus
Chickenman
I Am The Walrus!
Postby anthonym » Mon Aug 16, 2004 7:53 pm
Al wrote:3sgtes dont have forged pistons standard, they are cast.
I wouldn't be so sure about that. There is reasonable evidence that the 3SGTE pistons are made the same way as 4AGZE pistons (hyperutectic semi-solid forged IIRC).
anthonym
Postby anthonym » Mon Aug 16, 2004 7:56 pm
WALT3R wrote:Iv talked to a chap about that. It will fit, but there will be a hundred million little things that you have to change, waaaay too much f**king around. sound advice for anyone upgrading an engine, instead of putting a newer engine in, just buy the newer car.
Yep, unless you have a complete donor vehicle, I would agree with that.
anthonym
Postby Akane » Mon Aug 16, 2004 9:51 pm
All_Fours wrote:ahahaha
Try remove the big end bearing in your 3S-GTE, it will.... bah, screw it, why should I educate you?
Postby Chickenman » Tue Aug 17, 2004 1:07 am
Because then we can all share in your obviously superior knowledge :wink:
Baby Jesus
Chickenman
I Am The Walrus!
Re: Looking to purchase a 3sgte....
Postby furpo » Thu Aug 19, 2004 9:20 am
WALT3R wrote:Hey guys. I have a 1990 celica gt4 group a. Its sh*t itself big time. Iv been advised to look for anotha engine (its the big ends, will work out cheaper in the long run to get a new engine). Does anybody know of any up for grabs????? Turbo, intercooled, E-ST185H-BLI1NZ, 3SGTE. I am based in rotorua, but im sure freight will not be a problem so yeh, location is not an issue. I will need some sort of certification that shes a good'un, as you will understand. Thanks a lot. If u can find me sumthing that ends up worthwhile a box ov beers is in it for you. 8)
you could buy my whole car for $1500 keep the engine and sell everything else if you have the time. you will probably make $1000 back from it. it is in the mount too so you don't have to go far to get it.
roger
furpo
