Just find a quiet street and slam on the anchors at 50 - if you got ABS you'll feel the pulsing, if you dont then dont worry bout the light
Muzzie wrote:Just find a quiet street and slam on the anchors at 50 - if you got ABS you'll feel the pulsing, if you dont then dont worry bout the light
If the bulb has been removed because it had a fault in the system ( car dealer trick ) the car will have abs and the wheels will lock and you wont get any pulsing.
Mr Revhead wrote:If the bulb has been removed because it had a fault in the system ( car dealer trick ) the car will have abs and the wheels will lock and you wont get any pulsing.
or a warrant!
if the light is there, it must work. simple. if it hasnt got abs it wont have a lamp.
if your unsure look under the bonnet, abs modules arnt easy to miss...
Some warrant people are thick
or a warrant!
On a plus side - if you're speeding and lock up and hit something and the police get involved - they cant tell how fast you were going because the ABS dont lock the wheels Cant tell how fast you go from pulses because every car is different
