ABS AE111
ABS AE111
Postby HZRDIZ » Sun Aug 29, 2004 6:25 pm
Ok done a serch but cant find the answer im looking for...
Ok so some AE111s come with ABS, some dont. But does that mean that the ABS light should be there (ie there is place on the dash saying 'ABS') but whenever i turn my car on it never comes on or does a check or anything.
So basically asking if anyone else with a AE111 has noticed the same thing and know theirs doesnt have ABS but still has the light or because theyre all the same its just there to look pretty. Man i dont know if that made any sense...
Drinking 42 BELOW Passionfruit Vodka is like walking along the street and seeing this really hot girl and all you can think is "Man, I don't understand how anyone can be gay".
HZRDIZ
Postby B1NZ » Sun Aug 29, 2004 6:40 pm
yeah you confused me lol, If i correctly understood what you were trying to say then here is my answer:
Non ABS has the same dash with the same light, but the light wont glow when you turn the key on and do a check because ABS is not present.
If you have ABS and the light doesnt glow then you have a problem (although it most likely would be the bulb blown)
hopefully that helps :roll:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Muzzie » Sun Aug 29, 2004 6:57 pm
Just find a quiet street and slam on the anchors at 50 - if you got ABS you'll feel the pulsing, if you dont then dont worry bout the light :)
Mobile Car Servicing & Audio Installation - Inquire!
I'm Not Dumb, Im Just Selectively Observant!!!!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1036
Had flash sig, but too big for TS :(
Muzzie
Regular Poster
Postby levin_it_large » Mon Aug 30, 2004 6:20 pm
hmmm sounds like a GREAT idea
* goes off to find secluded area and slam on the brakes
BAH who needs a levin with ABS or airbags, they only safety features! :roll: :lol:
levin_it_large
Postby Muzzie » Mon Aug 30, 2004 6:22 pm
Damn straight :D
Who needs safety? Hehe
Muzzie
Regular Poster
Postby Dr-X » Mon Aug 30, 2004 7:31 pm
just dont crash and you'll be right 8O
Dr-X
Postby matt dunn » Mon Aug 30, 2004 8:08 pm
Muzzie wrote:Just find a quiet street and slam on the anchors at 50 - if you got ABS you'll feel the pulsing, if you dont then dont worry bout the light :)
Not a reliable way of telling.
If the bulb has been removed because it had a fault in the system ( car dealer trick ) the car will have abs and the wheels will lock and you wont get any pulsing.
Postby HZRDIZ » Mon Aug 30, 2004 9:23 pm
Ahhh i'll let Boosted Performance sort it out when it goes in. Im just gonna get everything done at once...
HZRDIZ
Postby Mr Revhead » Tue Aug 31, 2004 2:21 pm
or a warrant!
if the light is there, it must work. simple. if it hasnt got abs it wont have a lamp.
if your unsure look under the bonnet, abs modules arnt easy to miss...
Postby matt dunn » Tue Aug 31, 2004 8:22 pm
or a warrant!
Depends where you go for a warrant.
Some warrant people are thick.
They failed Dads camry cause the odo had been wound back.
Turns out they were reading the tripmeter not the odometer on the digi sort where you have to press the button to switch between the two.
If you dont know what to look for under the bonnet easiest thing to do may be sent Mr Revhead you chassis and frame numbers and he can probably tell you if it has abs.
Matt
Postby Mr Revhead » Wed Sep 01, 2004 12:14 pm
ill go with some ppl are thick!!
often the epc wont defferentiate between abs or non abs, it just lists 2 options! but i can try
Postby HZRDIZ » Wed Sep 01, 2004 10:57 pm
or a warrant!
Where would this ABS module be under the bonnet?
HZRDIZ
Postby matt dunn » Wed Sep 01, 2004 11:05 pm
HZRDIZ wrote:Where would this ABS module be under the bonnet?
Yes. Look for a alloy block with lots of steel brake pipes.
Postby qik20v » Thu Sep 02, 2004 12:01 am
mine also has an abs relay inside a black plastic box with...believe it or not...ABS relay written on the top
its at the front right of the engine bay, close to the headlight just above the radiator
1996 AE111 Toyota Levin BZ-G - 15.1 @ 146km
http://toyspeed.blakjak.net/profiles/profile.php?id=301
qik20v
Postby Bazda » Thu Sep 02, 2004 12:07 am
If u dont even know if u have ABS, obviously you drive like a granny :lol:
Postby levin_it_large » Thu Sep 02, 2004 11:53 am
and if u have neither ABS or airbags u r a $&#$% legend for not crashing!!!! :roll:
levin_it_large
Postby Muzzie » Thu Sep 02, 2004 12:04 pm
That makes me a legend :D
And just because you have an ABS symbol on the dash doesn't mean you have ABS - some car makers use the same dash to cut down costs and simply hook up what they want to - or what the new owner specifies that they want.
On a plus side - if you're speeding and lock up and hit something and the police get involved - they cant tell how fast you were going because the ABS dont lock the wheels :D Cant tell how fast you go from pulses because every car is different :)
Muzzie
Regular Poster
Postby Mr Revhead » Thu Sep 02, 2004 12:17 pm
true, thats possible
Postby levin_it_large » Thu Sep 02, 2004 6:31 pm
On a plus side - if you're speeding and lock up and hit something and the police get involved - they cant tell how fast you were going because the ABS dont lock the wheels Cant tell how fast you go from pulses because every car is different
is this is a TRUE fact :?: :?:
Now i hope to always buy a non ABS car just for this reason :roll: :roll: :wink:
levin_it_large
Postby Muzzie » Thu Sep 02, 2004 7:15 pm
Yeah it's true as far as I know, ive had police tell me this and a mate get off a speeding charge because he had ABS - because every car has different interval of pulses, and different length of time for each lock up. Could be handy if you hit the back of something or wipe out and the cops think you were speeding.
Instantly you get off the speed.
Muzzie
Regular Poster
Users browsing this forum: Google [Bot] and 53 guests
