Ceramic turbos?
Ceramic turbos?
Postby MRV8 » Mon Sep 27, 2004 6:25 pm
I have 2 ct20 ceramic turbos and 1 not ceramic. Whats the difference and which is better, and any idea what they are worth.
MRV8
Postby Al » Mon Sep 27, 2004 6:39 pm
Ummm what were they out of?
Do they look like this one
Al
Postby MRV8 » Mon Sep 27, 2004 7:00 pm
Sorta look like that, only have one exhaust port tho. One turbo off 2lthe out of hiace, the other off 2ct out of camry.
MRV8
Postby Al » Mon Sep 27, 2004 7:04 pm
Oh diesel ct20s...
ummm you will be lucky if you can give them away
Al
Postby Rollux » Tue Sep 28, 2004 1:43 pm
Could you swap the steel wheel onto ur CT20 Al? Or is A/R too different??
2002 Allex RS180 6 Speed
Racing a Honda is like competing in the Special Olympics. Even if you win, you are still a Retard.
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Oversteer is when the Passenger is scared. Understeer is when the Driver is scared
Rollux
Postby matt dunn » Sun Oct 03, 2004 11:01 pm
Ok, here's another turbo question for you al,
Guy i do work for has a ST185 GT4 as a race/rally car.
Do they have the ct20 /20b/26 etc and what should he have for best power and performance.
It runs link ecu etc so boost cut is no worries.
Matt
Postby Dell'Orto » Mon Oct 04, 2004 12:34 am
185's have the CT26...teh CT20B is supposed to be better all round, but finding a steel exhaust wheel one is tricky/expensive
Postby Al » Mon Oct 04, 2004 1:04 am
As Mmm, Boost said it will have a ct26
Best for power and reliabilty would be steel shaft ct20b from a WRC or export st205
i wouldnt actually go reccomending a ceramic turbo for rally purposes esp if he was gonna run 1bar + all the time id be too scared it would break, not because of the cost, but because you would be searching for a month before you found another one
Al
Postby Dell'Orto » Mon Oct 04, 2004 1:23 pm
Particularly if you're gonna be flash and run anti lag (is it a Link, or Link+?) as anti lag pretty quickly shatters ceramic wheels.
Users browsing this forum: No registered users and 22 guests
