jacko wrote:mount it on the bonnet.
Silent Knight wrote:jacko wrote:mount it on the bonnet.
...or if you drill 2 holes on the bonnet just above the throttle bodies there should be a mounting pin just to the left of the throttle body sensor where you can mount the tach so that it is in nice view of you jst in front of the steering wheel.
Then you can just plug it into the G sensor next to your oil cap wich will give you an exact reading right through your whole rpm range![]()
Mr Revhead wrote:i remeber there was a honda (i think) at the four and rotors in chch bout 2 years back that had gauges on the boot facing forwards......
phat_levin wrote:coz i think that the ones with the blu glow look really kool even tho theyre a waste of time, how do you mount them onto your dash without $$% it up??
pervert wrote:$$% idiots...
Just drill two holes and screw it down, when you take it off you can hardly see the holes...
phat_levin wrote:pervert wrote:$$% idiots...
i was trying to avoid $$% my dash if thats ok with you, and yes i do drive a 20v....
Users browsing this forum: Bing [Bot] and 40 guests
