any other info at all would be great, all my searches came up with levins/truenos.
Im just at the 'gathering of info' stage at the moment, so please no flaming posts of 'if you dont know wat you're doin dont bother doin it' bs
ae85trueno wrote:Know a guy Nick who did the conversion on his MR2, don't think he's on the forum, used the 4-AGZE block with a 20V head, custom inlet plenum, custom turbo headers, Link ECU etc, all done himself on a limited budget. Goes bloody brilliant, pumping out bout 240RWHP, and does the 1/4 in 12.4. Might be worth trying to get in contact with him.
Twolitre wrote:Why do you need an ecu and injectors? gmcrae turbocharged his AW11 with a TD04 and ran the stock gze injectors and ecu and apparently said the little car just flew even on moderate boost pressures.
MR2SIK wrote:cheers guys.
If i go ahead with this, it will be done in stages as the budget allows... meaning that Il be keeping as much as possible standard until the need for more power arises, doing the initial conversion and running slightly higher than standard boost (10psi or so) then upgrading fuel/ecu etc wen the $$$ refills, I also have the oppertunity to buy a RS legacy W2A I/C for dirt cheap in a couple of months, would that serve the purpose?
Thanks again
