wtd: info on turbo conversion for aw-11
Postby MR2SIK » Tue Jan 11, 2005 7:36 pm
Hey all, I been giving some thought into converting my 4agze aw-11 to turbo, just wondering how anyone else out there did for space between the exhaust manifold and the 'firewall' between engine bay and cabin.
any other info at all would be great, all my searches came up with levins/truenos.
Im just at the 'gathering of info' stage at the moment, so please no flaming posts of 'if you dont know wat you're doin dont bother doin it' bs :roll:
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby MR2boy » Tue Jan 11, 2005 8:10 pm
MR2boy
Postby vvega » Tue Jan 11, 2005 10:22 pm
its not hard
jsut need to be realistic on cost
youll need a maifold
a turbo and ecu and and injectors
and finally a intercooler
i fitted a to4e in mine so there is a little room down in there
pm me with your email i may be ablie to find some install piccys for you :d
v
vvega
Postby Twolitre » Wed Jan 12, 2005 12:00 am
Why do you need an ecu and injectors? gmcrae turbocharged his AW11 with a TD04 and ran the stock gze injectors and ecu and apparently said the little car just flew even on moderate boost pressures.
Twolitre
Postby ae85trueno » Wed Jan 12, 2005 12:18 am
Know a guy Nick who did the conversion on his MR2, don't think he's on the forum, used the 4-AGZE block with a 20V head, custom inlet plenum, custom turbo headers, Link ECU etc, all done himself on a limited budget. Goes bloody brilliant, pumping out bout 240RWHP, and does the 1/4 in 12.4. Might be worth trying to get in contact with him.
ae85trueno
Postby Al » Wed Jan 12, 2005 5:15 am
ae85trueno wrote:Know a guy Nick who did the conversion on his MR2, don't think he's on the forum, used the 4-AGZE block with a 20V head, custom inlet plenum, custom turbo headers, Link ECU etc, all done himself on a limited budget. Goes bloody brilliant, pumping out bout 240RWHP, and does the 1/4 in 12.4. Might be worth trying to get in contact with him.
He is on the forum under the guise mister2.
Al
Postby EVLGTZ » Wed Jan 12, 2005 7:55 am
Twolitre wrote:Why do you need an ecu and injectors? gmcrae turbocharged his AW11 with a TD04 and ran the stock gze injectors and ecu and apparently said the little car just flew even on moderate boost pressures.
injectors might be fine for a lil td04 but the limit is about 250hp. To get much more than this you'll need an upgrade
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby MR2SIK » Wed Jan 12, 2005 7:03 pm
cheers guys.
If i go ahead with this, it will be done in stages as the budget allows... meaning that Il be keeping as much as possible standard until the need for more power arises, doing the initial conversion and running slightly higher than standard boost (10psi or so) then upgrading fuel/ecu etc wen the $$$ refills, I also have the oppertunity to buy a RS legacy W2A I/C for dirt cheap in a couple of months, would that serve the purpose?
Thanks again :D
MR2SIK
Postby vvega » Wed Jan 12, 2005 7:31 pm
stock ecu and injectors will be fine for a small conversion
and will keep the conversion a little easier
guess its all dependant on your budget and what you want
v
vvega
Postby Malcolm » Wed Jan 12, 2005 9:51 pm
MR2SIK wrote:cheers guys.
Thanks again :D
The legacy w/a is an excellent choice. Fits in the stock location (but you need to move the battery), and is ideal for a mid engined car with few options for a/a intercoolers.
Finding the exact spot for the turbo is quite difficult, if you take the engine out then make sure you take good measurements of how much room you have in various directions and take note of things which will get in the way, like shifter cables, clutch lines, oil filter etc. We ended up putting mine above the exhaust manifold, about in line with the distributor, but your placement will depend heavily on what turbo you use
Postby MR2SIK » Thu Jan 13, 2005 10:42 pm
hey All_Fours, do you have any pics of your aw? Id be quite keen to check them out :D
MR2SIK
Postby Malcolm » Fri Jan 14, 2005 2:12 pm
at the moment the only pictures are of an empty aw11 engine bay and a few shots of progress, and none of them are digital yet. I was hoping to have the engine in this weekend but something has come up and I could be busy all weekend on another car.
Anyway once it's back in and running I'll get some pics.
Postby MR2SIK » Mon Jan 17, 2005 10:41 pm
sweet as, :D
MR2SIK
