3S-GE coolant drain plug
Postby Perky » Sun Jan 16, 2005 10:33 pm
Can anyone tell me whereabouts the coolant drain plug is on the engine block? It's a '94 3S-GE in a Curren. The Haynes manual amusingly shows a close-up of the plug to show you where it is. :roll:
Perky
Postby Twolitre » Mon Jan 17, 2005 12:53 am
From memory it's under the intake manifold on the gearbox end but is a real bitch to get at with the engine in the car due to the angle on which the engine sits.
Twolitre
Postby celica_tommo » Mon Jan 17, 2005 9:23 pm
I've flushed my cooland recently... that plug is damn hard to get at and I got absolutely soaked in antifreeze when i got it off :?
The plug is on the firewall side of the engine block on the gearbox side... I found it easiest to put my two longest extensions on a ratchet and come at it from above the exhaust pipe further towards the back of the car
good luck
celica_tommo
Postby Perky » Wed Jan 19, 2005 1:13 am
Thanks for that. Sounds difficult. Does the plug empty the block more effectively than repeated flushings out of the lower radiator tube? That's easy to remove.
Perky
Postby celica_tommo » Wed Jan 19, 2005 9:18 pm
I found there was a shitload of coolant sitting in the block obviously lower down than the radiator plug.... guess you could flush without removing the block plug
celica_tommo
Postby Perky » Wed Jan 19, 2005 10:36 pm
Yeah, the lower radiator tube emerges from quite high up on the block -- though I don't know how far down the water jacket goes. Repeated flushing does seem to clear everything out but it takes a while waiting for it to cool down and heat up. I flushed then used a cleaner and I'm about half way through.
I think I can see the block plug where you said it would be. But, since I don't have my axle stands or a really long socket extension, or even a good torch with me at the moment, it looks like even more of a PITA than multiple flushing.
Thanks for your help.
Perky
Postby celica_tommo » Fri Jan 21, 2005 11:43 pm
no problemo
celica_tommo
Users browsing this forum: No registered users and 36 guests
