10k 20v wrote:if it has duty cycle at the injectors it suggests the failure is between the ecu and the coil, (igniter etc). If there is no duty cylce then it suggests the ecu has no power, has no crank angle input (dist. faulty or connections) or the ecu is faulty.
just incase that helps
Ewan
