4age not running, no spark *help*
Postby AE85.6 » Wed Jan 19, 2005 6:20 pm
ok as far as i can tell power going to coil and to ignitor but no spark from coil lead at all, so could this still be either of them still ???
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby skoty » Wed Jan 19, 2005 7:31 pm
Is there power on BOTH sides of the coil??? You havn't snapped your cambelt have you otherwise your dizzy wont be rotating to make contacts with the points, that does actually happen. Have you checked the resistance in your HT leads, shouldn't be greater than 6 kilohms per foot.
skoty
Postby AE85.6 » Wed Jan 19, 2005 7:57 pm
yup power on both terminals on the coil, ht leads are ok and the one from coil to dizzy too, nup havnt snapped cam belt turns over fine just no spark to fire it off
AE85.6
Postby AE85.6 » Wed Jan 19, 2005 9:31 pm
ok borrowed a spare coil and ignitor sadly the problem is not either of them, all fuses are fine also.
what to check next ???
i thought:
1) the crank sensor possibly ??? but i thought if that has gone and the spark timing is off it would run poor not stop completely or stop a spark from the coil all together,
2) the ecu ?
not sure what else at the moment ???
AE85.6
Postby matt dunn » Wed Jan 19, 2005 10:49 pm
Possibly the dist.
The sensors have a habbit of going open circuit.
How many wires out of the dist? 3?
Matt
Postby AE85coupe » Thu Jan 20, 2005 8:06 pm
make sure the coil is properly earthed to the chasis, check its mounting bolt
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby AE85.6 » Fri Jan 21, 2005 1:45 pm
AE85coupe:
ye i wasnt sure if the mounting of the coil was also to earth it, but original coil was mounted sweet and i tried a different coil so i dont think it would be this,
matt dunn:
ah crap not by my car at the mo, i think from memory it is three but ill try swing past after work and check,
AE85.6
Postby 10k 20v » Fri Jan 21, 2005 1:49 pm
just remember toyots iginters earth themselves to the chassis, and if there not bolted up they don't work, probly no the problem but such simple things can cause so much of a headache
check to see if there is injector duty cycle
10k 20v
Postby AE85.6 » Sat Jan 22, 2005 11:09 am
matt dunn:
ah i see, yup it has 3 wires going into the dizzy, red white and blue
10k 20v:
injector duty cycle ??? you mean to see whether they are actually working or ???
AE85.6
Postby AE85.6 » Sat Jan 22, 2005 12:45 pm
bump
AE85.6
Postby matt dunn » Sat Jan 22, 2005 6:23 pm
do you have or have acess to a volt/ohm meter?
Postby AE85.6 » Sun Jan 23, 2005 11:47 am
yup old man has one so when he gets home later o i can use it, hmmm mite be able to find another one thou, a mate has a spare dizzy also so i was prob just gonna try swapping that over to see what happens, cause i noticed the crank angle sensor also says "do not remove" and toyota say they dont even sell them you have to buy a new dizzy so i spose worth a shot to try,
failing that thou when i have a volt metre i can check out those three wires for what you tell me theyu should be doing 8)
cheers again all, not fair thou im starting to get withdrawls from not driving it hehe
AE85.6
Postby matt dunn » Sun Jan 23, 2005 9:49 pm
There's three wires in there,
dont remember what's what but easy to work out.
Call the A B C.
A to B should be 150 - 180 ohms from memory,
A to C should be 150 - 180 ohms too,
C to B should be 300 - 360 ohms.
that's the first test.
Postby AE85.6 » Mon Jan 24, 2005 1:48 pm
ok mate had a spare dizzy so tried swapping the whole thing,
sadly still had no spark so i think the problem is before the dizzy but what to check now cause ive pretty much run out of ideas,
looks like it could be a trip to the auto sparkie me thinks
AE85.6
Postby matt dunn » Mon Jan 24, 2005 5:29 pm
Weird thing are a happening?
Just on the off chance,
take off the dist cap, crank it over, and see if the rotor spins.
Matt
Postby AE85.6 » Tue Jan 25, 2005 1:29 pm
ye rotor spins round fine but no spark to spread around to the points in the cap,
i thought this could be the case a while ago too but even if it was not spinning it should still send a spark from the coil lead wouldnt it ?
but yes it is spinning around,
i think it must just have a broken wire somewhere or a bad connection of some kind that has been getting worse and now has finally let go ???
AE85.6
Postby 10k 20v » Tue Jan 25, 2005 6:56 pm
if it has duty cycle at the injectors it suggests the failure is between the ecu and the coil, (igniter etc). If there is no duty cylce then it suggests the ecu has no power, has no crank angle input (dist. faulty or connections) or the ecu is faulty.
just incase that helps
Ewan
10k 20v
Postby matt dunn » Tue Jan 25, 2005 10:04 pm
10k 20v wrote:if it has duty cycle at the injectors it suggests the failure is between the ecu and the coil, (igniter etc). If there is no duty cylce then it suggests the ecu has no power, has no crank angle input (dist. faulty or connections) or the ecu is faulty.
Ewan
Yes, that is a good way of determining if the fault is an input or output fault,
but unfortunatly not many people have the ability to test duty cycle as a lot of multi-meters dont have duty cycle function. and with the engine only doing cranking speed a lot of cheap meters dont pick up the small duty cycle you may get.
Matt
Postby 10k 20v » Wed Jan 26, 2005 8:14 pm
thats true, i just use a led test light to determine if duty cycle is present, quick and easy. You need to check that on mitsi's all the time :D :D :D
Chow
10k 20v
Postby AE85.6 » Tue Feb 01, 2005 5:34 pm
cool thankyou, anyone else have any clues ?
AE85.6
