AE92 s/c , n/a 4age wiring
Postby crispy'86 » Sun Jan 30, 2005 5:27 pm
I need any links besides club4ag and 4agze to give me the pin outs for the ae92 gtz and ae92 auto models, using loom, ecu from auto trueno with my n/a replacement engine in gtz ae92. I Before people go saying things like " use the original loom, i can't cause the engine runs tvis and diferent plugs. don't think i've got all the sensors to get the n/a engine to run with s/c ecu.
Any help appreciated
crispy'86
Postby ee904age » Sun Jan 30, 2005 6:01 pm
Whats wrong with http://www.club4ag.com/faq%20and%20tech ... 92%204A-GE%. I used nothing but that to wire my 4AG from scratch.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby ee904age » Sun Jan 30, 2005 6:06 pm
Dam, link doesnt work and I cant be bothered working it out so here you go.
ECU Connections AE92 1988-1989 Japan Spec
Socket A (Yellow 14 pin)
Pin # Color Label (ECU) Connection
1 B-R B1 EFI Main
2 R-W Batt BATT
3 Blu-G CCO Exhaust Temp Sensor
4 G-R FC Curcuit Opening relay(fuel)
5 R ECT ECT-S (Suspension Control)
6 Y-R L3 ECT-S (Suspension Control)
7 Y-Blu L1 ECT-S (Suspension Control)
8 B-R B EFI Main
9 R-Y W Check Engine Lamp
10 R EGW Exhaust Temp Warn. Lamp
11 B-W A/C Air Conditioner clutch
12 V-W SPD Speed Sensor (instrument panel)
13 not used
14 Y-G L2 ECT-S (Suspension Control)
Socket B (18pin Yellow)
1 W THW Water Temp Sensor
2 Blu-G PIM Vaccuum Sensor
3 W THA Intake Temp Sensor
4 G-R #10 1/3 Injectors
5 B-Y IGF Ignitor
6 B G1 Distributor
7 W G- Distributor
8 B OX O2 sensor
9 B V-ISC Idle Up Diode
10 BR E2 Throttle Position Sensor
11 R VTA Throttle Position Sensor
12 Y VCC Vaccuum Sensor
13 Blu IDL Throttle Position Sensor
14 not used
15 R NE Distributor
16 BR E21 Vaccuum Sensor
17 R-W VF Diagnosis Connctor
18 G-R STH VSV TVIS
Socket C (10 pin Yellow)
1 B-W NSW Neutral Start Switch
2 not used
3 B-W STA Starter
4 G-R #10 Injector #1,#3
5 BR E01 Ground
6 not used
7 BR E1 Ground
8 B IGT Ignitor
9 G-Y #20 injector #2,#4
10 BR E02 Ground
90 SW20 N/A - Sold
ee904age
ae92
Postby crispy'86 » Mon Jan 31, 2005 12:08 pm
Yup got that wiring off club4ag but the s/c loom has a 22 pin plug and i may have to tap into it. I've got print out of both pin outs for the ecu's. I'll try it tonight and figure which wires i have to swap etc. Watch this space, any probs i'll reply to this post
crispy'86
ae92
Postby crispy'86 » Mon Jan 31, 2005 9:16 pm
Okay i need the ecu pin out for 4agze, 24, 10, 18 pin afm type
crispy'86
Postby ee904age » Mon Jan 31, 2005 10:12 pm
http://www.geocities.com/MotorCity/Lane ... outs3.html I have never worked on a GZE so it may or may not be of any use to you. Good luck.
Shay
90 SW20 N/A - Sold
ee904age
Re: ae92
Postby matt dunn » Tue Feb 01, 2005 12:49 am
crispy'86 wrote:Okay i need the ecu pin out for 4agze, 24, 10, 18 pin afm type
Good luck. If you ever find it let me know.
I searched for days and the AE92 AFM one is the only one you cannot find,
and the pins inside the ECU are not labelled like some are.
Matt
ae92
Postby crispy'86 » Tue Feb 01, 2005 8:56 pm
The link ee904age gave me is the same as waht i got off club4ag, that one comes from mr2 afm 4agze which is what it says. Same pin out for ecu and i've got wiring for map 4agze. I just hope the wires are the same colour and do the same things on afm and map. Apart from the obvious one running map sensor, other running afm
crispy'86
Re: ae92
Postby matt dunn » Tue Feb 01, 2005 11:09 pm
crispy'86 wrote:The link ee904age gave me is the same as waht i got off club4ag, that one comes from mr2 afm 4agze which is what it says. Same pin out for ecu and i've got wiring for map 4agze. I just hope the wires are the same colour and do the same things on afm and map. Apart from the obvious one running map sensor, other running afm
I think you'll find that they are different.
There are even differences in the ecu pinout's between AE92 map and AE101 map ECU's. ( as i found out when i tried to fit AE92 Map ecu to a AE101 Map loom, neddles to say it would not work.)
matt
Re: ae92
Postby matt dunn » Tue Feb 01, 2005 11:17 pm
matt
AE92
Postby crispy'86 » Wed Feb 02, 2005 7:53 am
Matt, i think you may be right with that but as long as the wires are same colours and i can suss them out.
EE904age: I thought the ect-s stands for auto trans aswell as tems. I say this cause i have the loom with the ect trans infront of me and those 3 wires marked y-r etc go to this plug to the auto trans comp. So any ideas if i can bypass this for auto i guess?? Neutral start switch bypasing? Matt any ideas?
crispy'86
Postby ee904age » Wed Feb 02, 2005 12:21 pm
My loom never had the 14 pin plug so the only pins on that socket I used are the two EFI Main ones and the Batt pin and just left all the others unused, whether this will work with the auto ECU I dont know. I presume you are using a manual box? If it doesnt work there are a couple of manual ECU's on trademe for about $20.
90 SW20 N/A - Sold
ee904age
ae92
Postby crispy'86 » Wed Feb 02, 2005 12:24 pm
Did you have all your dash lights etc aswell. I may tryit but the plug for the dash the wires on this are different, one yellow plug smaller than ecu plug. I can try it the way you had yours. Can you give me the link to the ecu's and are they for ae92?
crispy'86
ae92
Postby crispy'86 » Wed Feb 02, 2005 12:58 pm
Another question: On the inside where there are the different plugs to the loom there is a 6 pin black rectangular plug, wires on the gtz loom on inside are: r/b *2. b/w *2. b/y*1. w/b*1. The red top connector has same apart from the b/y on gtz loom, red top is just plain black. I tried to make a link wire up to change the wires to the right colours. Any idea what the b/y wire is on the gtz plug?. I sorted the starter wire etc but as all isn't plugged up i won't know if the injector resistor is plugged up properly. I tried it and got it cranking but had 12v at injector plugs :oops: maybe i'll plug everything up now i have oil pressure up and try it with r/t loom plugged in as ee904age suggested
crispy'86
Postby ee904age » Wed Feb 02, 2005 5:42 pm
Are you using a big aor small port engine? IIRC you can use a bluetop ECU on an AE92 Bigport in which case http://www.trademe.co.nz/Trade-Me-Motor ... 955823.htm , or http://www.trademe.co.nz/Trade-Me-Motor ... 707352.htm will do the job. My bluetop ecu matces those AE92 pinouts so I dont think there is a difference. Cant help with the dash lights as I kept my original lomm in there and used that for the oil pressure/water temp/alternator lights and tacho.
90 SW20 N/A - Sold
ee904age
Postby matt dunn » Wed Feb 02, 2005 9:00 pm
ee904age wrote:Are you using a big aor small port engine? IIRC you can use a bluetop ECU on an AE92 Bigport in which case http://www.trademe.co.nz/Trade-Me-Motor ... 955823.htm , or http://www.trademe.co.nz/Trade-Me-Motor ... 707352.htm will do the job. My bluetop ecu matces those AE92 pinouts so I dont think there is a difference. Cant help with the dash lights as I kept my original lomm in there and used that for the oil pressure/water temp/alternator lights and tacho.
You would have been comparing to the AW11 bigport GZE which still runs a dist. This will be about the same as the early bluetop's,,
But the AE92 onwards have a CAS and multi coil and so they are not the same as the AE82/AE86 ecu's.
Matt
Postby ee904age » Wed Feb 02, 2005 9:29 pm
Sorry, im talking NA ecu's in both cases. ie. Bluetop Ecu with bigport Redtop.
90 SW20 N/A - Sold
ee904age
ae92
Postby crispy'86 » Thu Feb 03, 2005 1:00 pm
ee904age; I'm talking about that plkug which has the wiring for the tachometer etc, i may be after that plug( little yellow one) with length of wire to simplify the wiring for it and tidy it up a bit. Got it running last night, just basic engine control for now until i wire in the dash tacho etc then tidy it up.I'm using the red top ecu and used 3 wires, still have to wire in the speed sensor etc. Put radiator etc in, engine revs high but may change when i get the vacuum hoses etc all hooked up.
crispy'86
ae92
ee904age; I'm talking about that plkug which has the wiring for the tachometer etc, i may be after that plug( little yellow one) with length of wire to simplify the wiring for it and tidy it up a bit. Got it running last night, just basic engine control for now until i wire in the dash tacho etc then tidy it up.I'm using the red top ecu and used 3 wires, still have to wire in the speed sensor etc. Put radiator etc in, engine revs high but may change when i get the vacuum hoses etc all hooked up. You could say it's running big port head as it's the blue top head.
crispy'86
ae92
Postby crispy'86 » Fri Feb 04, 2005 7:47 am
so anyone got those plugs in the above mentioned post?
crispy'86
