crispy'86 wrote:Okay i need the ecu pin out for 4agze, 24, 10, 18 pin afm type
crispy'86 wrote:The link ee904age gave me is the same as waht i got off club4ag, that one comes from mr2 afm 4agze which is what it says. Same pin out for ecu and i've got wiring for map 4agze. I just hope the wires are the same colour and do the same things on afm and map. Apart from the obvious one running map sensor, other running afm
ee904age wrote:Are you using a big aor small port engine? IIRC you can use a bluetop ECU on an AE92 Bigport in which case http://www.trademe.co.nz/Trade-Me-Motor ... 955823.htm , or http://www.trademe.co.nz/Trade-Me-Motor ... 707352.htm will do the job. My bluetop ecu matces those AE92 pinouts so I dont think there is a difference. Cant help with the dash lights as I kept my original lomm in there and used that for the oil pressure/water temp/alternator lights and tacho.
Users browsing this forum: No registered users and 32 guests
