i was told it was the diffs that came out standard with LSD's that had disc brakes, whereas the non-lsd diffs had drum brakes.
l1ttle_d3vil wrote:the "ae86" diff that ive got has drum brakes. i was told it was the diffs that came out standard with LSD's that had disc brakes, whereas the non-lsd diffs had drum brakes.
NZ_AE86 wrote:To the best of my knowledge the only AE86 diffs that had drums were Ozzie assembled cars that had a single cam 4a engine! (Although I have seen Toyota do some odd things!)
If it is a true AE86/4AGE diff it will have discs. Although the diff head can be the same size and have drums so the discs will not affect strength.
NZ_AE86 wrote:I have been thinking about this and unless I saw one I would not believe that any AE86 that had a factory fitted 4AGE came with drums.
crispy'86 wrote:And an important thing that hasn't been pointed out is that the ae85's had drum brakes as you all know but MORE IMPORTANTLY: AE85 DIFFS ARE 8 BOLT AE86 DIFFS ARE 10 BOLT. This is on the diff flanges where the head bolts to the housing. I'm surprised none of you pointed this out cause it's one of the more distinguishing features between the both of them
