smallport 4age + bigport ecu/tvis
Postby Truenotch » Thu Feb 24, 2005 7:55 pm
Hey does anyone know whether a bigport tvis will fit onto a smallport 4age. Im putting a smallport in my mr2 but don't want to have to get an aftermarket ecu or have to fit the ecu& wiring loom from the ae92 fxgt donor. I was thinking of trying to fit the tvis on without the actual tvis butterfly set up. Any help would be a big help as i want to get the car on the road asap.
Truenotch
Postby ee904age » Thu Feb 24, 2005 8:09 pm
No, it wont. I dont think the manifold will even bolt on, if it does the ports will be a mile off with or without the tvis plate.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Truenotch » Thu Feb 24, 2005 8:16 pm
Sweet as ill have to sort out a way of making it work. Thought it wouldn't fit. Do you know if the smallport manifold has similar ecu connections to the tvis one??? I think it would be a mission to get the whole loom out of the other car to fit that ecu plus i would have to do the bridging thing because the donor cars an auto......
Truenotch
Postby Truenotch » Thu Feb 24, 2005 9:15 pm
On the other hand do you think the smallport motor would work on the bigport ecu/loom keeping the smallport intake manifold? I guess I'm wondering whether the loom connections are the same on the two manifolds.
Truenotch
Postby ee904age » Thu Feb 24, 2005 9:25 pm
I could be wrong but I think smallports are afm, if so then no you are stuck that way aswell.
90 SW20 N/A - Sold
ee904age
Postby AE85coupe » Thu Feb 24, 2005 9:28 pm
smallports are map
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby Truenotch » Thu Feb 24, 2005 9:36 pm
Yeah the motor runs on a map not afm so im hoping the two will connect up. The other option i might use is to put the bluetop head (from the broken motor) on the strengthened bottom end of the redtop. with a mild skim on the head and a .5mm trd headgasket then i could use the tvis and standard wiring, while still having the strength. I think this would be a good option as long as the cams/valves etc are all ok.
Truenotch
Postby low_rider » Thu Feb 24, 2005 9:43 pm
it will run sweet i had a smallport engine in my fx
rulk
low_rider wrote:BRING BACK COMMUNAL SHOWERS!!!!!!!!!!!!!
http://toyspeed.blakjak.net/profiles/profile.php?id=336
low_rider
Postby Truenotch » Thu Feb 24, 2005 9:44 pm
running it on a bluetop ecu???
Truenotch
Postby Zak » Thu Feb 24, 2005 11:41 pm
I have a 100kw red top, and it was running very rich. So we tried using a blue top ECU, it worked fine. Didn't fix ma problem though :evil:
So you should be able to run it with the blue top ECU and loom
Zak
Postby RedMist » Fri Feb 25, 2005 7:03 am
Zac, thats warped.
The redtop smallport has bigger injectors than the bluetop. So the bluetop ECU needs to fire the injectors for longer in order to inject enough fuel for the bluetop to run. When installed in the redtop it still fires the injectors for the same period but now has the bigger redtop injectors. IE it will run very rich.
Don't know what happened in your case Zac, but I've a friend here in CHCH swapped a bluetop ECU into a redtop smallport engine, he was forced to change the injectors as it ran stupidly rich.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Drifter4ag » Fri Feb 25, 2005 9:22 am
it will run find with the bluetop ecu and injectors and sensors
just use all manifolds from the small port and also the fuel rail.
Doesnt run lean
makes good power could go as high as 90kw@wheels in stock form with this setup
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
JZX91 MARK II CHASER
Drifter4ag
Postby Zak » Fri Feb 25, 2005 9:36 am
RedMist wrote:Zac, thats warped.
I never said it ran well, I just said it ran. But you would have to use the blue top injectors, and other things like that... You could probably get it running in the end though.
Zak
Postby spencer » Fri Feb 25, 2005 12:01 pm
just fit the smallport ecu it will save the headache its no that much of a major
ms63 crown
spencer
Postby Truenotch » Fri Feb 25, 2005 4:06 pm
i would use the smallport ecu but i don't wanna have to get the loom out of the other car (which is a corolla) and try and put it in my aw11 mr2. It would be too much of a mission unless the bluetop loom connects to the smallport ecu....
Truenotch
Postby Zak » Fri Feb 25, 2005 10:31 pm
Well, the ecu plugs in, and most other stuff seams to. And I'm running a small port motor with a big port loom, it's not exactly running like a dream though... :(
I think it's still running the tvis ECU though, so it might explain some of it.
Zak
Postby Truenotch » Sat Feb 26, 2005 12:55 pm
Yea could pose some problems... Well i guess ill see when it comes to it...
Truenotch
Postby BL8KK9T » Sat Feb 26, 2005 11:59 pm
just do it man, i did the same thing on a ae92 just used the tvis loom and ecu, it runs sweet.
yes officer, our sober driver is right behind us
BL8KK9T
Postby Truenotch » Mon Feb 28, 2005 8:48 pm
Got the motor home and have had a look at it. Seems the injector connections aren't the same, so i might have to use the bluetop ones unless i can change the plugs over...... not sure. But shouldnt be too long now hopefully
Truenotch
Postby 4ageman » Tue Mar 01, 2005 12:30 am
I had a small port in my celica awhile back running off the bluetop ecu and loom. all you have to do is change over the injecters and sensors and distrubuter and tps sensor for the bigports ones. so just change every thing electrical over and you can use your bluetop ecu and loom
4ageman
Users browsing this forum: No registered users and 22 guests
