help!!! blue top cams
Postby FLAWLES » Thu Mar 24, 2005 5:47 pm
i " we " have just put some blue top cams in my gtz
we have timed them spot on
we have spark
we have fuel
dignostics are a-o-k
but no start, it cranks over but no go
we thought it was a pressure increase in the intake manifold killing the car " due to my aftermarket ecu " but we diconected it and run it on the factory ecu and still no go?
someone help us or manily me :?
FLAWLES
Postby trdfxgt » Thu Mar 24, 2005 5:56 pm
with out knowing how much you know about timing and things could it be 180 degrees out ?
trdfxgt
Postby FLAWLES » Thu Mar 24, 2005 6:03 pm
trdfxgt wrote:with out knowing how much you know about timing and things could it be 180 degrees out ?
mmmmmmmmm i see :roll:
like i said the timming is spot on
FLAWLES
Postby ee904age » Thu Mar 24, 2005 6:14 pm
Whats it sound like when cranking? ie:good compression, trying to fire/not trying etc...
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby FLAWLES » Thu Mar 24, 2005 6:18 pm
Yea good compression
no vlves hitting " non interfearince engine remember :wink: "
we nearly got it firing once but just for a split second
FLAWLES
Postby ee904age » Thu Mar 24, 2005 6:21 pm
Well not being to clued up on the gze all I can say is check over all sensors etc that may have been touched in the process, but you have probably already done that.
90 SW20 N/A - Sold
ee904age
Postby FLAWLES » Thu Mar 24, 2005 6:26 pm
yea check
the map sensor doensnt need to be at a sertin height does it :?: :?
FLAWLES
Postby ATAl » Thu Mar 24, 2005 6:30 pm
Have any fuses blown?
Are the injectors firing? (I know you said you've got fuel but that could just be at the line)
Cambelt tension correct - could be slipping?
ATAl
Postby FLAWLES » Thu Mar 24, 2005 6:44 pm
mmmmmm injectors have not check those you bring up a valid point..... az my fuel press reg gauge is jumping around the place az soon az we stop cranking the engine over
but yea cambelt tensoin sweet as are fuses :D
FLAWLES
Postby Adamal » Thu Mar 24, 2005 6:58 pm
If the cam belt were slipping, you'd definatly hear a difference.
Has putting the cams in been the only thing you've done to it since it was last running? Nothing else you've tampered with?
Postby Lloyd » Thu Mar 24, 2005 7:01 pm
As with any problem with starting, first things to check are fuel and spark. Make sure you have those and go from there.
Postby Dr-X » Thu Mar 24, 2005 7:06 pm
You have spark, you have fuel. Assuming all you've done is change the cam, there's only 2 possibilities - either your cam timing is out, or your dizzy is out 180deg. Triple check it.
Dr-X
Postby Lloyd » Thu Mar 24, 2005 7:17 pm
Ummm..... if this is in a GTZ and its MAP sensored then you'd have a crank angle sensor instead of a distributor, correct?
Postby dohca » Thu Mar 24, 2005 11:37 pm
HRT wrote:Ummm..... if this is in a GTZ and its MAP sensored then you'd have a crank angle sensor instead of a distributor, correct?
yep
same with the dli AFM version
dohca
Postby vvega » Fri Mar 25, 2005 12:06 am
when you get sick of tring to sort it tow it over and ill sort it for you :D
hahha
v
vvega
Postby NZ_AE86 » Fri Mar 25, 2005 8:29 am
Dr-X wrote:You have spark, you have fuel. Assuming all you've done is change the cam, there's only 2 possibilities - either your cam timing is out, or your dizzy is out 180deg. Triple check it.
Could this be the the NEW DR-X???
I agree with him. :? 8O
NZ_AE86
Postby vvega » Fri Mar 25, 2005 9:00 am
lol i know very impressed with the change around in info and practical advice :D
he is becomming dare i say it a asset to the toyspeed comunity :d
v
vvega
Postby Lloyd » Fri Mar 25, 2005 9:44 am
Are all the crank/cam angle sensors in the GTZs the same, geared onto the cam? As opposed to the likes of some distributors that have a set way they can go in and thats the only way.
If you've ever removing your CAS then mark it with the engine at TDC so you know where to put it back in. Been there and not done that before...
Postby ChaosAD » Fri Mar 25, 2005 11:02 am
FYI, if timing is 180 deg out the timing light wont show that as the crank turns twice for every one turn of the cam.
ChaosAD
Postby FLAWLES » Fri Mar 25, 2005 6:21 pm
vvega wrote:when you get sick of tring to sort it tow it over and ill sort it for you :D
hahha
v
WILL DO I JUST NEED SOMETHING TO TOW IT WITH..........hold on we will came and get you my cars at thaphattys place
this will be easyer
FLAWLES
