fivebob wrote:Remove the ballast resistor. It should be located on the rear firewall, behind the plenum.
fivebob wrote:Rewire it, the resistor goes between the injectors and +12v from the IGN relay. Probably best to get a resistor pack with the correct plugs from someone like Pick-a-Part and use the plugs from that if you don't want to butcher your resistor pack.
Depending on the resistance of the injectors you might be able to get away without removing it, but I wouldn't recommend it as it will increase injector lag times.
Also when tuning for the new injectors you will need to change the battery voltage compensation table. Did the injectors come with any Voltage vs Lag data?
