3SGTE injector impedance
Postby Lloyd » Sun Apr 17, 2005 7:47 pm
Hey, they are all low in every generation of the 3S-GTE aren't they? And are a direct replcement for the silvertop ones?
Postby fivebob » Sun Apr 17, 2005 9:34 pm
They are low in all the models that used side feed injectors (Gen II & III), the Caldina has high impedance top feed, don't know the impedance of the Gen I top feeds.
Postby vvega » Sun Apr 17, 2005 9:46 pm
fivebob wrote:They are low in all the models that used side feed injectors (Gen II & III), the Caldina has high impedance top feed, don't know the impedance of the Gen I top feeds.
they are low as well, they carry a resistor pack for them on the firewall..
v
vvega
Postby Lloyd » Sun Apr 17, 2005 11:03 pm
Good good, and anyone know if they slot into the silvertop holes?
Postby Twolitre » Mon Apr 18, 2005 12:07 am
HRT wrote:Good good, and anyone know if they slot into the silvertop holes?
Yes they do.
Twolitre
Postby gmacrae » Tue Apr 19, 2005 12:50 am
while we're talking about 3sgte injectors, does any generation of 3s have side feed low impedance 500+cc injectors that'd fit my jza80 fuel rail?
gmacrae
Postby fivebob » Tue Apr 19, 2005 11:17 am
gmacrae wrote:while we're talking about 3sgte injectors, does any generation of 3s have side feed low impedance 500+cc injectors that'd fit my jza80 fuel rail?
Gen III are 540cc low impedance side feeds.
Postby Boosted_162 » Sun May 10, 2009 5:05 pm
Just bringing up a very old thread... Ive got a gen 3 turbo with 540cc low impedance side feed injectors. I have a set of Sard 850cc high impedance side feed injectors. Do i need to do anything to fit them? I know going from high impedance to low impedance you need to fit a ballast resistor? or something, but not sure about the other way round.
Postby fivebob » Sun May 10, 2009 5:24 pm
Remove the ballast resistor. It should be located on the rear firewall, behind the plenum.
Postby Boosted_162 » Sun May 10, 2009 5:27 pm
fivebob wrote:Remove the ballast resistor. It should be located on the rear firewall, behind the plenum.
Do i just unplug it or do i need to do some rewiring to remove it? Thanks Fivebob!!
Postby fivebob » Sun May 10, 2009 5:44 pm
Rewire it, the resistor goes between the injectors and +12v from the IGN relay. Probably best to get a resistor pack with the correct plugs from someone like Pick-a-Part and use the plugs from that if you don't want to butcher your resistor pack.
Depending on the resistance of the injectors you might be able to get away without removing it, but I wouldn't recommend it as it will increase injector lag times.
Also when tuning for the new injectors you will need to change the battery voltage compensation table. Did the injectors come with any Voltage vs Lag data?
Postby Boosted_162 » Sun May 10, 2009 6:01 pm
fivebob wrote:Rewire it, the resistor goes between the injectors and +12v from the IGN relay. Probably best to get a resistor pack with the correct plugs from someone like Pick-a-Part and use the plugs from that if you don't want to butcher your resistor pack.
Injectors didnt come with anything as they came from Sean/MR2SIK. Standard injectors measure 3.5 ohms, while sard's measure 14.9.
Also, before i figured out they were high impedance i had tried to run it. Now when i try run it (on standard 540's) it misses on idle. Obviously ive stuffed something due to my stupidity, what should i look for? Would like to get it running now until my RC goes, then i dont need the MR2 and can rewire it.
Postby xnickx » Tue May 19, 2009 10:22 am
xnickx
