Is there a formula to work out what size injectors are required for X horsepower? I need some injectors for a 16v 4age capable of handling 180Hp.
Would my ae82 fxgt fuelpump be up to the task? or would I also need a replacement Fuelpump?
ChaosAD wrote:I think they will be a bit big. gtz injectors are around the 390 mark.
I was thinking that the 290ish 20v injectors would be a good size as they supposedly make 160Hp standard. So maybe something that size but top feed.
ChaosAD wrote:Thanks. So its either rb20 or 4afte injectors.
What about the fuel pump? it only runs 180ish injectors standard.
Should I get a 20v levin one?
