How do I calculate required injector flow rates?
Postby ChaosAD » Mon Apr 25, 2005 12:10 pm
Is there a formula to work out what size injectors are required for X horsepower? I need some injectors for a 16v 4age capable of handling 180Hp.
Would my ae82 fxgt fuelpump be up to the task? or would I also need a replacement Fuelpump?
ChaosAD
Postby Lloyd » Mon Apr 25, 2005 12:19 pm
I've got some GTZ ones for sale just incase you discover they are about what you need :)
Postby ChaosAD » Mon Apr 25, 2005 12:24 pm
I think they will be a bit big. gtz injectors are around the 390 mark.
I was thinking that the 290ish 20v injectors would be a good size as they supposedly make 160Hp standard. So maybe something that size but top feed.
ChaosAD
Postby the fallen303 » Mon Apr 25, 2005 12:53 pm
290cc injectors should flow enough for around 200hp at the engine using the formula i have here. can't remember where i got it from, think an old performance car, or fast fours, something along those lines. put it into excel, so i use it through there.
true house of JZ
Stay true to the origin
the fallen303
Postby ChaosAD » Mon Apr 25, 2005 1:04 pm
Cheers. What engines have top feed 290ish injectors in them?
ChaosAD
Postby ChaosAD » Mon Apr 25, 2005 1:15 pm
http://www.meggala.com/injectors.htm
Would the skyline rb20det flow enough?
ChaosAD
Postby unit-Equip » Mon Apr 25, 2005 1:23 pm
ChaosAD wrote:I think they will be a bit big. gtz injectors are around the 390 mark.
Starlet turbo (ep82 or ep91) : 295cc/min @ 13.8ohms and top feed. I always understood 4A-GZE to be a low impedence 365cc top feed unit. Sold some the other week to Braided Lines in Australia for their turbo'd 4EFE starlet running TD04L rex 'charger.
Cheers,
Paul. ;)
unit-Equip
Postby ChaosAD » Mon Apr 25, 2005 2:10 pm
Thanks. So its either rb20 or 4afte injectors.
What about the fuel pump? it only runs 180ish injectors standard.
Should I get a 20v levin one?
ChaosAD
Postby unit-Equip » Mon Apr 25, 2005 2:19 pm
ChaosAD wrote:Thanks. So its either rb20 or 4afte injectors.
Starlet uses a 4E-FTE. (E series engine).
Cheers,
Paul. ;)
unit-Equip
Postby ChaosAD » Mon Apr 25, 2005 2:25 pm
sorry. meant to say 'RB20DET or 4efte injectors'.
So does anyone know about the pump?
ChaosAD
